I have a 2001 Neon ACR and I am getting a little popping sound on take off from the front end, not bad but noticeable. I have also noticed that the front end feels like it "wanders" a little on some roads. I have checked the tie rod ends and lower ball joints they seem fine, if I push down and the front end it rebounds nice and firm and doesn't bounce or anything. I am leaning toward lower control arm bushings being worn but wanted other suggestions in case there is a pattern problem with these cars. The car hasn't been abused or hot rodded since new so the front end hasn't seen anything more than normal driving. THanks for any advice out there.
