will worn upper ctrl arm bushings make the brakes pull? #798046
09/10/10 04:29 PM
09/10/10 04:29 PM
DELAWARE
TONY_DAGOSTINO Offline OP
DELAWARE
hi
i have a car here that the brakes are giving us fits
it pulls to the right
all brake items have been replaced, the lines blown out, etc
just noticed the rf upper control arm bushing is pretty well worn, + the left front upper control arm bushing has some wear to it.
have any of you any experiance with worn upper control arm bushings making the brakes pull?
btw, it goes down the road straight, + doesnt make any nnoises and turns normally
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798047
09/10/10 04:32 PM
09/10/10 04:32 PM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
did you replace the rubber flex hoses on the front?,if not thats where i would start
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798048
09/10/10 04:36 PM
09/10/10 04:36 PM
scratchnfotraction Offline
yes,worn bushing will let the control arm move around throwing the alinment off and pull when on the brakes
if it spits the rubber all the way out it will stay out of alinement and get a clunking sound when on/off the brakes
if its worn and the bolt is off center in the rubber bushing they need replaced(crushed/worn/sagging)
new bushing tighten up a front end a whole lot when all the BJ and bushings are done at the same time...dont forget..the strut rod bushing could be worn and let it move around also
they are over looked a lot when trouble shooting front end work
make sure the rear drums are spooned up = on both sides while your at it,IMHO
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: rhad] #798049
09/10/10 04:36 PM
09/10/10 04:36 PM
DELAWARE
DELAWARE
yes, the rubber hoses, brake valves, wheel cylinders front + rear were changed
the fluid pressure is great and consistent all the way around
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798050
09/10/10 05:31 PM
09/10/10 05:31 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
A car that pulls under braking typically has
a. A significant difference side-to-side in coefficient of friction
and/or
b. A significant difference side-to-side in effective fluid pressure reaching the calipers/brake cylinders
and/or
c. A significant difference side-to-side in caster.
If the car does not exhibit any pull when not under braking, this would generally require a significant shift in caster when applying the brakes. Does the front end "clunk" or show wheel shift when observed from outside when the brakes are applied? If the answer is no, then your problem more likely lies in area a. or b. above.
Which is not to say that worn front-end parts shouldn't be addressed at some point...
Down to just a blue car now.
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: 68HemiB] #798051
09/10/10 06:03 PM
09/10/10 06:03 PM
DELAWARE
DELAWARE
HI
no clunking at all is heard
the rf wheel will lock up
(the wheel cylinders were replaced twice)
if not holding the wheel, when you hit the brakes hard it will turn to the right
it goes down the road straight + doesnt pull when you let off of the wheel, until you hit the brakes
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798052
09/10/10 06:13 PM
09/10/10 06:13 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Sounds like a. or b., then.
You say "wheel cylinders", so we're talking front drums?
If so, make sure there isn't some bonehead oops like reversed primary/secondary shoe positions. Remember that secondary [rear] shoes are typically darker and/or longer.
Regardless of the brake type, consider swapping the front hard parts and shoes/pads side-to-side. If the pull stays the same, chase hydraulics. If the pull jumps to the other side, chase lining contamination and hard part surface quality.
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: 68HemiB] #798053
09/10/10 06:15 PM
09/10/10 06:15 PM
spoon opposite side up some
yea what he said..drums on the front
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: scratchnfotraction] #798054
09/10/10 06:23 PM
09/10/10 06:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just remember drum brakes are like a mullet. Short in front long in back.
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: 68HemiB] #798055
09/10/10 09:17 PM
09/10/10 09:17 PM
DELAWARE
DELAWARE
great input, thanks guys
were changing the upper control arm bushings now, figure they should be done anyway, whether theyre the problem or not
i just went out and checked out some of the brake checks i made on a concrete pad that shows skid marks alot better than asphalt
the 2 rears skidded evenly, the right front skidded alittle more than the rears, no skid mark from the left front
yes, the shoes are on correctly, learned about self energizing shoes in my preteen years
"Regardless of the brake type, consider swapping the front hard parts and shoes/pads side-to-side. If the pull stays the same, chase hydraulics. If the pull jumps to the other side, chase lining contamination and hard part surface quality. "
exactly what we were going to try after we did the upper control arm bushings
thanks again, ill keep ya posted
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798056
09/10/10 10:20 PM
09/10/10 10:20 PM
spoon the one with no skid up some
that should get it turned around
JK ya
drums x4 are a little horse and buggy for now days,differant methed thats almost forgotten now days
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: scratchnfotraction] #798057
09/10/10 10:51 PM
09/10/10 10:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
any worn ft end part will cause braking issues. ck the strut rod and lower control arm bushings as well.
also ck the idler and pitman arms
like said if everything is good, and you still have brake pull issues, swap the shoes and see what it gets you
Re: will worn upper ctrl arm bushings make the brakes p [Re: gtx6970] #798058
09/11/10 08:37 PM
09/11/10 08:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I changed my strut rods to the RM units and it changed the braking like night and day
I think struts have more to do with brake pull than any other suspension component
Gus
64 Plymouth Savoy
Dana 60
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: scratchnfotraction] #798059
09/11/10 08:48 PM
09/11/10 08:48 PM
Alexandria,La.
BigTerry Offline
BigTerry  Offline
Alexandria,La.
my 2 cents on the rubber brake line!
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: rhad] #798060
09/13/10 10:16 AM
09/13/10 10:16 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
That is were I would start. Recently worked on a car with pulling brakes and the rubber hoses were bad as well as a few wheel cylinders.
logan426
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: MLR426] #798061
09/13/10 01:58 PM
09/13/10 01:58 PM
DELAWARE
DELAWARE
hi
in the begining of the thread i had posted that all 3 rubber lines were changed (2 front + 1 rear)
thanks again
tony
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798062
09/13/10 05:47 PM
09/13/10 05:47 PM
Lynnwood Washington
rp23g7 Offline
rp23g7  Offline
Lynnwood Washington
Yes it would, i just finished this project.
My left lower bushing was shot, it was spinning in the bore, thus causing my strut rod bushing to wear,
Mine would clunk and when it did the steering would change due to the shifting around of the lower control arm. Afer replacing the bushing it steers like a dream now. I just drove it 400 miles, gonns check everything to see if its tight still and go get the alignment checked one more time
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798063
09/19/10 12:15 PM
09/19/10 12:15 PM
DELAWARE
DELAWARE
got it
it was the brake shoes
they were like new, not stained or showing any signs of not being good
switched the shoes from left to right, + it pulled to the left instead of the right
so we replaced with a new set, now it stops straight
i have never run across that before
thanks for the help
tony
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798064
09/19/10 12:20 PM
09/19/10 12:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Do you think they might have been differnt brands/types from left to right. Like someone just did one side?
Think something could got on the shoes once and was cleaned or burned off?
Weird one.
got it
thanks for the help
tony
Re: will worn upper ctrl arm bushings make the brakes pull? [Re: TONY_DAGOSTINO] #798065
09/19/10 11:23 PM
09/19/10 11:23 PM
MN
astrobuf Offline
astrobuf  Offline
MN
got it
thanks for the help
tony
So, I wonder of the issue is that the left and right show set had different arc's on them. A factory griding error couldhave miss-arc'd one of the primary shoes and you'd then end up with a pull untill it wore in. Not a contamination problem, probably a production problem!
Astrobuf
So, are you really a Rocket Scientist?
