What would cause a motor to Diesel when turned off? #797995
09/10/10 02:55 PM
09/10/10 02:55 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
helping a friend with his motor and we cant figure out why it Diesels so bad. as soon as you turn the key off, it continues to try and run. we changed fuel, tried a different carb, checked timing. He had someone tell him that due to his MSD system, that there is still power going to the coil which causes the run on.
I think is unspent fuel still in the cyinders.
could use some help here.
Re: What would cause a motor to Diesel when turned off? [Re: AK_JH27] #797996
09/10/10 03:07 PM
09/10/10 03:07 PM
IMGTX Offline
IMGTX  Offline
Dieseling is caused by something hot in the combustion chambers igniting the gas. This causes the engine to turn over creating vacuum which draws more fuel out of the carb (just like it was running) which enters the combustion chamber ignites and continues.
If the voltage to the MSD is switched off it has no effect.
The most common fix from the factory is to use a solenoid to set the idle speed. When the ignition is turned off the solenoid de-energizes and the throttle plates completely close and it will stop dieseling.
High combustion chamber heat can be caused by lean mixture, ignition timing, or high compression.
An alternate is to shut the car off and then hold the throttle open. The dieseling will not allow fast rpm's (in most cases) so the vacuum drops and the fuel stops being drawn out of the carb.
I prefer the solenoid option if available.
or EFI
Re: What would cause a motor to Diesel when turned off? [Re: AK_JH27] #797997
09/10/10 03:07 PM
09/10/10 03:07 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
Try lowering the idle speed.
Re: What would cause a motor to Diesel when turned off? [Re: Ply72rr] #797998
09/10/10 03:11 PM
09/10/10 03:11 PM
IMGTX Offline
IMGTX  Offline
DOH! I forgot that one.
Re: What would cause a motor to Diesel when turned off? [Re: IMGTX] #797999
09/10/10 03:26 PM
09/10/10 03:26 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
Duh! Didnt think about the throttle plates. I'll try that
Re: What would cause a motor to Diesel when turned off? [Re: AK_JH27] #798000
09/10/10 03:32 PM
09/10/10 03:32 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I did read somewhere that in some cases the MSD can cause this. There is some sort of device that can be used to prevent this.
Other causes could be as someone said, high idle speed, or the fuel not having enough octane, or too hot a plug.
Re: What would cause a motor to Diesel when turned off? [Re: torkrules] #798001
09/10/10 04:40 PM
09/10/10 04:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Ignition or timing cannot effect dieseling/run on other than in adjusting the timing it will a lot of times effect the idle speed.
Ignition or timing need voltage to operate and create spark. When the key is turned off there is no longer power to the ignition.
Re: What would cause a motor to Diesel when turned off? [Re: MoparforLife] #798002
09/10/10 04:53 PM
09/10/10 04:53 PM
morrisville, pa
skajm Offline
skajm  Offline
morrisville, pa
steam clean your chambers. get a dollar store spray bottle fill with water. remove air clean start motor and slowly spray water into carb. rev motor as you spray. this will clean chamber of carbon build up.
joe
Re: What would cause a motor to Diesel when turned off? [Re: skajm] #798003
09/10/10 06:20 PM
09/10/10 06:20 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Running hot, idle set to high, low octane gas, carbon buildup in combustion camber, timing.
Re: What would cause a motor to Diesel when turned off? [Re: Ply72rr] #798004
09/10/10 06:39 PM
09/10/10 06:39 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Re: What would cause a motor to Diesel when turned off? [Re: rapom] #798005
09/10/10 07:04 PM
09/10/10 07:04 PM
Upper Midwest
Upper Midwest
Once again not timing. Can't happen. Key off - no power.
Re: What would cause a motor to Diesel when turned off? [Re: MoparforLife] #798006
09/10/10 07:43 PM
09/10/10 07:43 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
disagree
It's Swifty! Swifty, you toad sucker!
Re: What would cause a motor to Diesel when turned off? [Re: zrxkawboy] #798007
09/10/10 07:47 PM
09/10/10 07:47 PM
Upper Midwest
Upper Midwest
Like I said the only way timing can effect engine run on is by slowing the idle speed down with the timing adjustment. the timing itself CANNOT effect run on as spark needs voltage and the timing controls the when the spark occurs. With the ignition off spark is killed.
Re: What would cause a motor to Diesel when turned off? [Re: MoparforLife] #798008
09/10/10 08:15 PM
09/10/10 08:15 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
timing can cause the engine to run hot, and the overly hot chamber temps can then cause dieseling, and that much easier if there is carbon or casting hot spot (burr)in a chamber also. But most common I think is excess idle speed.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: What would cause a motor to Diesel when turned off? [Re: zrxkawboy] #798009
09/10/10 09:14 PM
09/10/10 09:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
disagree
If you give it more intial timing, then you can close the throttle blades more at idle which often is enough to prevent run on.
So I'm thinking timing can effect run on/dieseling...
Re: What would cause a motor to Diesel when turned off? [Re: torkrules] #798010
09/10/10 09:26 PM
09/10/10 09:26 PM
thats only with GM's.. you need a one way diode to prevent it.
Re: What would cause a motor to Diesel when turned off? [Re: MoparforLife] #798011
09/10/10 10:44 PM
09/10/10 10:44 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
See reply by Go Fish above.
Re: What would cause a motor to Diesel when turned off? #798012
09/11/10 10:36 AM
09/11/10 10:36 AM
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
That was it.
