Re: What would cause a motor to Diesel when turned off?
[Re: AK_JH27]
#797996
09/10/10 03:07 PM
09/10/10 03:07 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Dieseling is caused by something hot in the combustion chambers igniting the gas. This causes the engine to turn over creating vacuum which draws more fuel out of the carb (just like it was running) which enters the combustion chamber ignites and continues. If the voltage to the MSD is switched off it has no effect. The most common fix from the factory is to use a solenoid to set the idle speed. When the ignition is turned off the solenoid de-energizes and the throttle plates completely close and it will stop dieseling. High combustion chamber heat can be caused by lean mixture, ignition timing, or high compression. An alternate is to shut the car off and then hold the throttle open. The dieseling will not allow fast rpm's (in most cases) so the vacuum drops and the fuel stops being drawn out of the carb. I prefer the solenoid option if available. or EFI
[Re: AK_JH27]
#798000
09/10/10 03:32 PM
09/10/10 03:32 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
helping a friend with his motor and we cant figure out why it Diesels so bad. as soon as you turn the key off, it continues to try and run. we changed fuel, tried a different carb, checked timing. He had someone tell him that due to his MSD system, that there is still power going to the coil which causes the run on. I think is unspent fuel still in the cyinders.
could use some help here.
I did read somewhere that in some cases the MSD can cause this. There is some sort of device that can be used to prevent this.
Other causes could be as someone said, high idle speed, or the fuel not having enough octane, or too hot a plug.
[Re: Ply72rr]
#798004
09/10/10 06:39 PM
09/10/10 06:39 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Try lowering the idle speed.
[Re: rapom]
#798005
09/10/10 07:04 PM
09/10/10 07:04 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Running hot, idle set to high, low octane gas, carbon buildup in combustion camber, timing.
Once again not timing. Can't happen. Key off - no power.
[Re: MoparforLife]
#798008
09/10/10 08:15 PM
09/10/10 08:15 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
timing can cause the engine to run hot, and the overly hot chamber temps can then cause dieseling, and that much easier if there is carbon or casting hot spot (burr)in a chamber also. But most common I think is excess idle speed.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: zrxkawboy]
#798009
09/10/10 09:14 PM
09/10/10 09:14 PM
Challenger 1
Cincinnati, Ohio
Ignition or timing cannot effect dieseling/run on
disagree
If you give it more intial timing, then you can close the throttle blades more at idle which often is enough to prevent run on.
So I'm thinking timing can effect run on/dieseling...
[Re: torkrules]
#798010
09/10/10 09:26 PM
09/10/10 09:26 PM
thats only with GM's.. you need a one way diode to prevent it.
#798012
09/11/10 10:36 AM
09/11/10 10:36 AM
torkrules
I'm neurotic
I'm neurotic
That was it.
