Page 2 of 3 1 2 3
Re: 727 lasted 8 passes [Re: dragram440] #797695
09/11/10 05:21 PM
09/11/10 05:21 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
My tranny guy said there is nothing in the tranny that would come apart that woudnt stick to the magnet in the pan. I dont know much about tranny's
No one else said it, so I will. You need a new tranny man.
I would suggest as others have. Get the books, a core trans, and a clean bench. Go slow and pay attention to detail. They are not difficult at all. If you like building engines, you will probably enjoy building transmissions.
Re: 727 lasted 8 passes [Re: Bigbeep] #797696
09/11/10 05:27 PM
09/11/10 05:27 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Mega DITTOS to that
Re: 727 lasted 8 passes [Re: Bigbeep] #797697
09/11/10 08:14 PM
09/11/10 08:14 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
but your tranny guy is flatly wrong, there are other materials other than ferrous metals in a transmission.
Re: 727 lasted 8 passes [Re: dartman366] #797698
09/12/10 01:15 AM
09/12/10 01:15 AM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Get Carl Munroe's Torqueflight book. It is excellent! Between that book, and some excellent advice from a few members here, I've learned that automatic transmissions are NOT the black magic that many back yard mechanics think they are. I've rebuilt 3 727's since I joined Moparts, all of them quite successful. Doesn't take too long to learn enough to do it yourself and not only save bucks, but do the work it really needs!
Re: 727 lasted 8 passes [Re: dartman366] #797699
09/12/10 01:37 AM
09/12/10 01:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.lofgrenauto.com/
While I have no doubt that CRT could hook you up with a top notch trans.... this one is driving distance from you. Chuck builds a dang good torqueflight.
Re: 727 lasted 8 passes [Re: J_BODY] #797700
11/29/10 02:25 PM
11/29/10 02:25 PM
bigfork mn
dragram440 Offline OP
bigfork mn
Well I finally got my tranny back to the tranny guy and he said it broke the rear bolt in sprag and wrecked the case. He said it could possibly be from driver error even though I drove the car just as he told me to.
Re: 727 lasted 8 passes [Re: dragram440] #797701
11/29/10 03:20 PM
11/29/10 03:20 PM
louisiana
71440dart Offline
71440dart  Offline
louisiana
i had the same thing happen with that valve body, mine was from driver error, but i didnt tear up the case, it did tear up the bolt in sprag, i thought thats what the bolt in sprag was for, to save the case?
71 dodge dart race car,440/727 best so far: 11.23 @119 74 plymoth duster, 408SB/727
Re: 727 lasted 8 passes [Re: 71440dart] #797702
11/29/10 03:39 PM
11/29/10 03:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No, the bolt in sprag is to REPAIR a case that has had the outer race spin but not enough to ruin the case. Unless you buy the A+A or Coan Super/Ultimate sprags, they have more rollers and make it virtually impossible to have a sprag failure, you can still lay the rollers over in a bolt in. All the bolts do is stop the outer race from spinning in the case.
Re: 727 lasted 8 passes [Re: dragram440] #797703
11/29/10 03:47 PM
11/29/10 03:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
will a basically stock 727 hold up to around 650 hp or do I need to completly upgrade.It has a turbo action valve body and the tranny guy said he put a 5.0 shift lever or arm in it. and a tci rebuild kit, whatever that consists of.
Sorry to hear this although I`m hearing it more often. My trans guy is one of the best ANYWHERE and for $680.00(my price) he rebuilt mine 7 years ago and rollerized it and put in a bolt in sprag. Don`t know what your problem is and not exactly sure of my hp in terms of durability but a basic build SHOULD live if the builder knows what the hell he`s doing.
Re: 727 lasted 8 passes [Re: dragram440] #797704
11/29/10 04:45 PM
11/29/10 04:45 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
9 out of 10 Coan converters require a bell housing spacer. Did you install one if required?
8.30's @3400 lbs
Re: 727 lasted 8 passes [Re: Mike Swann] #797705
11/29/10 05:23 PM
11/29/10 05:23 PM
bigfork mn
bigfork mn
No spacers in it. It looked to me you only needed them if you were running a mid plate or if the converter was to far back. Would that cause the rear sprag to go south.
67' charger 499 RB 10.57 at 127
Re: 727 lasted 8 passes [Re: dragram440] #797706
11/29/10 07:11 PM
11/29/10 07:11 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
turbo action valve body? thats the problem my friend just went through that w his 727
Re: 727 lasted 8 passes [Re: fishy340] #797707
11/29/10 09:08 PM
11/29/10 09:08 PM
virginia
572stealth Offline
572stealth  Offline
virginia
What's your burnout procedure?
Re: 727 lasted 8 passes [Re: JohnRR] #797708
11/29/10 10:23 PM
11/29/10 10:23 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
The case can still get broken with a bolt in sprag. The rollers can get jammed so hard that they spread the outer race of the sprag, expand it and crack the case. Don't ask me how I know
Re: 727 lasted 8 passes [Re: dragram440] #797709
11/29/10 11:02 PM
11/29/10 11:02 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Just what "error" is he referring to??
If you like drag racing, support your local track.
Re: 727 lasted 8 passes [Re: CHAPPER] #797710
11/29/10 11:25 PM
11/29/10 11:25 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
How bout "tranny man" advice ERROR!
Re: 727 lasted 8 passes [Re: CHAPPER] #797711
11/29/10 11:43 PM
11/29/10 11:43 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I build my own 727's, but not too often. The one in the car now was run for 2 years, freshened up and then sat for 13 years before I disassemblled it, checked every thing and reassembled it (only new parts on the freshen up were seals, and clutches). The transmission was then installed and I have run it for 3 seasons (300 plus passes per season). It will be freshened up this winter. My car car is a foot brake car that leaves with the front tires in the air every pass. 60' 1.37, 1/8 6.53/105, 1/4 10.38/127.
Don't let anyone tell you that a Turbo Action RMVB won't work, I've had mine for 25 years. The convertor is a Turbo Action 17509J. It has been repaired 3 times in 10 racing seasons.
I agree with others, you need a new trans guy. That guy can be you.
Brian Dunnigan
Re: 727 lasted 8 passes [Re: dragram440] #797712
11/30/10 12:26 AM
11/30/10 12:26 AM
fullmetaljacket Offline
Too bad you are that far away. Curtis SR. who runs Turbo Torque out of Brooklyn, NY builds some of the simplest and reliable 904's and 27's on the market. His transmissions hang out in the 600-800 HP range with no sweat.
He has tricks and knowledge that even Chrysler has faulted on.
In the case,(917) 602-4239 Curtis Sr. 65 years old and still cranking them out.
Re: 727 lasted 8 passes [Re: dragram440] #797713
11/30/10 12:51 AM
11/30/10 12:51 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I agree on doing it your self. I built mine several years ago. Get a book and a Mancini overhaul kit and have at it, it's not that bad.
Re: 727 lasted 8 passes [Re: FastmOp] #797714
11/30/10 10:57 AM
11/30/10 10:57 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Not sure if I'm qualified to post in this forum............haven't raced in a few years.
But, I have rebuilt a 727 lately and I also recommend doing it yourself. The only "special tools" you'll need is an inch-pounds torque wrench, some snap-ring pliers, dial-indicator & stand/clamp, feeler gauges and a makeshift workbench with a hole in it to load the tailshaft/low-rev drum into the case.
The recommended book by Munro and a FSM will cover nearly every question stock or modified.
What isn't clear you can ask about it here.
The 727/904 is a VERY basic planetary-style transmission.
Page 2 of 3 1 2 3
