Best repro fuel and brake lines? #796541
09/08/10 09:06 PM
09/08/10 09:06 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Who makes the best repro fuel and brake lines?
I need em for a 69 hemi charger and a 71 440-6 cuda.
Re: Best repro fuel and brake lines? [Re: domingo] #796542
09/08/10 09:09 PM
09/08/10 09:09 PM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Fine Lines get's my vote!
http://www.finelinesinc.com/
Re: Best repro fuel and brake lines? [Re: LYNCHROAD69.5] #796543
09/08/10 10:24 PM
09/08/10 10:24 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Re: Best repro fuel and brake lines? [Re: rayztoy] #796544
09/09/10 01:10 AM
09/09/10 01:10 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
X2....I've tried the others, nothing compares to Finelines,...I do recommend their stainless steel repro lines though,....do the car once, do it right
Mike
Re: Best repro fuel and brake lines? [Re: DAYCLONA] #796545
09/09/10 04:45 PM
09/09/10 04:45 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I prefer The Right Stuff Detailing stainless lines. I have both of their fuel and brake lines on my car and have had 0 problems. I'd use them again anytime.
1968 Plymouth Road Runner 383 4 speed
Re: Best repro fuel and brake lines? [Re: dobie] #796546
09/09/10 05:50 PM
09/09/10 05:50 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
i would have said fine lines,but since they don't really back up the sales,i'd go with right stuff,i bought the full brake line kit from fine lines,though all fit well the proportioning valve and drivers front brake line,had poor flanging and they wouldn't replace,now i have to buy new else where
Re: Best repro fuel and brake lines? [Re: meepmeep70] #796547
09/09/10 10:31 PM
09/09/10 10:31 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks for the replies. I will check into both and compare....It'd be nice to get stainless lines, even though not correct, I dont mind....stainless rocks!!!
Re: Best repro fuel and brake lines? [Re: domingo] #796548
09/09/10 10:42 PM
09/09/10 10:42 PM
Ohio
dobie Offline
dobie  Offline
Ohio
For what its worth, my uncle had Fine Lines ss brake lines on his Challenger a few years back. He never could get them to seal properly and always had a leak. They wouldn't back their product either, and he ended up taking them off and replacing them with Right Stuff lines. No further problems as long as he had the car. As for me, no problems with either their fuel or brake lines.
Re: Best repro fuel and brake lines? [Re: dobie] #796549
09/09/10 10:46 PM
09/09/10 10:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
well, a poor seal is always a bad flange....if thats the case I can reflange em with the proper equipment....not that I'd like to do so of course....
do they both make SS lines?
Re: Best repro fuel and brake lines? [Re: domingo] #796550
09/09/10 10:51 PM
09/09/10 10:51 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Domingo,
If you still have the originals (fuel and brake lines) you might want to consider using them as patterns and making your own, a few simple tools (tubing bender/cutter/flare tool) the correct fittings, some tubing, and spiral covering is all you need. They usually fold the reproductions in half when shipped to reduce the length so you have to straighten them anyway. It's not all that difficult to make them and it will save you a TON in shipping/customs, etc.
Re: Best repro fuel and brake lines? [Re: domingo] #796551
09/09/10 10:51 PM
09/09/10 10:51 PM
Illinois
SteveA Offline
SteveA  Offline
Illinois
I tried stainless steel lines on my car and had leaks. I went with the regular steel lines and didn't have a problem.
Steve
Re: Best repro fuel and brake lines? [Re: SteveA] #796552
09/09/10 10:55 PM
09/09/10 10:55 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
You guys have to know how to "seat" stainless lines properly if you don't want them to leak. It's a simple process that will solve any leaks if you do it during installation.
Another HUGE vote for Fine Lines
CHECK OUT MY NEW WEB SITE !
Re: Best repro fuel and brake lines? [Re: SteveA] #796553
09/09/10 10:56 PM
09/09/10 10:56 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I believe they both offer stainless stuff. I know mine are. As for shipping, yeah that could be a hassle. I picked mine up at a swap meet, so i didn't have to worry about that.
Re: Best repro fuel and brake lines? [Re: dobie] #796554
09/09/10 11:02 PM
09/09/10 11:02 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Well, i have no idea how to "seat" them properly. I know that all i did was install them and have had zero leaks with mine. I doubt my uncle did anything different either in switching from fine lines to right stuff. Sounds like user preference really. I've had good luck with right stuff, so i'll always recommend them. Whatever you go with, good luck!
Re: Best repro fuel and brake lines? [Re: anlauto] #796555
09/09/10 11:12 PM
09/09/10 11:12 PM
Illinois
SteveA Offline
SteveA  Offline
Illinois
I did, still leaked for me.
Steve
Re: Best repro fuel and brake lines? [Re: ScottSmith_Harms] #796556
09/09/10 11:18 PM
09/09/10 11:18 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Domingo,
Yes, Ive done mine b4 using originals as patterns but there is a lot of time invloved. I had to bend em, then have them tin plated, I also had to have the spring custom made to fit over the line snugly, then plate the spping too....bend all the lines, then after tehy were bent take em on my pickup bed to have em flanged at a good hydraulic flanger, etc. Man lots of time...time has to be worth something....I have the chance to put em inside a container so there is no shipping costs for me there this time!!! Here is a pic when I was testing fit with the proo valve...thats why the prop valve bracket was still rusty.
How should I seat the stainless lines properly???
Re: Best repro fuel and brake lines? [Re: anlauto] #796557
09/10/10 12:11 AM
09/10/10 12:11 AM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Alan,
Could you share with us how you seat them properly?
Ray
Re: Best repro fuel and brake lines? [Re: rayztoy] #796558
09/10/10 08:28 AM
09/10/10 08:28 AM
anlauto Offline
anlauto  Offline
Alan,
Ray
Simple, using the proper wrench you tighten the fitting the best you can, then back it off and tighten it again. Do that two or three times for each fitting.
I also prefer to assemble as much as possible outside on the bench like the proportioning valve pictured above and the rear axle, etc...
This method has cured my problems I've had with stainless lines. For OE lines I find the extra steps not necessary.
Re: Best repro fuel and brake lines? [Re: anlauto] #796559
09/10/10 09:28 AM
09/10/10 09:28 AM
WI
RestoRick Offline
RestoRick  Offline
WI
A dab of antiseize on the threads helps too... allows you to tighten them a bit more and will save your butt down the road if you have to remove any of 'em.
Rick
Re: Best repro fuel and brake lines? [Re: RestoRick] #796560
09/10/10 03:56 PM
09/10/10 03:56 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Alan & Rick,
Thank you so much for the 'TIPS'!
Ray
