70-74 E-body 1/4 glass rear guides not on some cars ? #796227
09/08/10 01:31 PM
09/08/10 01:31 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
Hey guys, we're running through some of our ebodies here and noticed not all of them have the rear 1/4 glass rear guides installed... were they only on certain models or years ??
none of the ragtops have them, those are kind of obvious... our 70 cuda has them, our 70 challenger has the bracket for them but no guide installed and our 73 and 74 cudas have the top bracket but not the bottom bracket that holds the track to the wheelhouse.... ??? Most of the above are untouched cars... They don't appear to do much other than guide the bottom inch of the point on the glass, did chrylser dump them in 71?
Restoration, Sales and Canadian Distributor For:
AMD Sheetmetal
Wizzard Direct Fit, Bolt In Aluminum Radiators
Legendary Interiors
SSBC & Wilwood Brakes
Control Freak Suspensions
Fine lines Tubing
and many more...
www.macleanclassics.com
Re: 70-74 E-body 1/4 glass rear guides not on some cars ? [Re: smac77] #796228
09/08/10 02:01 PM
09/08/10 02:01 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Yep...mid 1971 model year
CHECK OUT MY NEW WEB SITE !
Re: 70-74 E-body 1/4 glass rear guides not on some cars ? [Re: smac77] #796229
09/08/10 02:07 PM
09/08/10 02:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
My 73 Challenger has a guide welded to the inner structure of the quarter that the crank mechanism arm slides in. Then the glass track is held in with one bolt at the top and is adjustable at the bottom with a large stud. That's it. I have no idea if that is the same or different than other years.
Re: 70-74 E-body 1/4 glass rear guides not on some cars ? [Re: anlauto] #796230
09/08/10 02:53 PM
09/08/10 02:53 PM
Caledon, Ontario
smac77 Offline OP
smac77  Offline OP
Caledon, Ontario
would it be safe to say they were pretty much useless !
AMD Sheetmetal
Legendary Interiors
Fine lines Tubing
and many more...
