Re: How do I get a leaf spring car to hook up?
[Re: taildragger]
#796018
09/08/10 04:05 AM
09/08/10 04:05 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
FWIW, I use 002/003 SS springs QA-1 single adjustable shocks and no snubber in the rear. Up front is all stock except the usual '73 & up disc brake swap, CE shocks set to 90/10, /6 bars and about 5" of travel. Been 1.38's in the 60' and still tuning Never had an issue with the car not going straight & true. If you do then you need to start measuring the car.
[Re: roadhazard]
#796019
09/08/10 04:08 AM
09/08/10 04:08 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
use Caltrac in front and rear and your problem is solved
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
[Re: taildragger]
#796022
09/08/10 08:22 AM
09/08/10 08:22 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
The new SS springs are poor quality and yes, they are made in Mexico.
Launchers seem to work good (I'd use them before SS springs any day), but I haven't seen any on really quick cars. They may be out there, but I haven't seen em.
The fastest leaf spring cars in the country are running Cal-Tracs. Enough said.
[Re: taildragger]
#796025
09/08/10 02:47 PM
09/08/10 02:47 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Launching with leafs is all in 2 things good movement in the front end(try for 5" minimum) and SHOCKS... good shocks... its in the control of the body raising cant have it going up too fast.... while alot of guys use the Rancho 9 way on the rear alot of times you will be at max or near max on the settings
[Re: MR_P_BODY]
#796026
09/08/10 11:37 PM
09/08/10 11:37 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
It can be done. You need your combo to work together. Engine, gear, converter, front and rear suspension, tires, weight placement, ect. My combo has taken a while to sort out, but well worth the time and effort. '72 E body Barracuda 3200# 14 point roll cage +.030 440 calvert front shocks 727 home built Turbo Action "J" converter Turbo Action man valve body SS rear springs (Mesican made) NO snubber NO caltracts 4:56 Dana w/spool Mickey Thomp 11.5 X 29.5 1.39 60' 6.59, 102 mph 1/8 mile 10.49, 127 mph 1/4 mile
If I can help you, PM me on here.
Brian Dunnigan
[Re: taildragger]
#796028
09/11/10 12:04 AM
09/11/10 12:04 AM
MR_P_BODY
Do you have /6 bars up front ... gives you more stored energy to assist the front lift... caltrac front shocks are pretty decent for the fronts... get 5" of front movement
[Re: MR_P_BODY]
#796029
09/11/10 12:12 AM
09/11/10 12:12 AM
'72CudaRacer
Mooresburg, Tn
I agree with Mike. My car has a stock front end (replacement moog parts, tie rod ends, idler arm, upper and lower ball joints) 6 cyl torsion bars, calvert front shocks, stock steering box. Adjustments are as much caster as possible, camber 0*, toe in 1/8", with all settings made 1.5" above static height.
Brian
