I want to lose my MP cam and crappy idle - suggestions #795409
09/07/10 01:00 PM
09/07/10 01:00 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
So.... this is new territory for me, usually Im trying to go bigger not smaller.
This is for the 440 4bbl in my 'Bird, I have stock compression, iron dual plane intake, edelbrock 750 vac sec carb. Currently I have the MP purple shaft cam with 60 degrees of overlap, poor vacuum at idle etc...
This car is a cruiser and street car, I'm seriously considering just going back to the stock cam and seeing how it runs. I'm looking for good idle and torque, and a redline of under 5,000 RPM. also, I have a good double rolled timing chain in it, I've seen kits that contain the OEM style non roller chains. Since this will be a stock 440, is there any real advantage of a double roller, and is there a downside to using the "quieter" stock chains?
Any input will be helpful as I am pretty lost when it comes to cam selection It seems there are way too many choices out there, and I just want a decent running car.
Re: I want to lose my MP cam and crappy idle - suggestions [Re: 70Sbird] #795410
09/07/10 01:09 PM
09/07/10 01:09 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
Something like an RV cam would probably work well for you. Stock timing set up should work well too.
Re: I want to lose my MP cam and crappy idle - suggestions [Re: 70Sbird] #795411
09/07/10 01:12 PM
09/07/10 01:12 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
The Summit 224/234-465/488 cam works well and has a good idle and pulls good vacuum. The smaller cam (214/224-455/465 I think) works pretty well too.
Coming soon!!!!
Re: I want to lose my MP cam and crappy idle - suggestions [Re: dmerc] #795412
09/07/10 01:13 PM
09/07/10 01:13 PM
MP .528/284 adv. duration mechanical.
Nice smooth idle and tons of power.
Re: I want to lose my MP cam and crappy idle - suggestions #795413
09/07/10 01:19 PM
09/07/10 01:19 PM
the summit cam 6401( the bigger one) is a fantastic street cam--one of the best running out there--don't care about how the specs look--it runs great!
Re: I want to lose my MP cam and crappy idle - suggestions #795414
09/07/10 01:21 PM
09/07/10 01:21 PM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
The cam choice is all in what you are looking for. But on the timing chain I would still use the double roller setup. After only a couple hundred miles the stock ones feel like they are worn out.
I always use the double roller.
Re: I want to lose my MP cam and crappy idle - suggestions [Re: 70Sbird] #795415
09/07/10 02:23 PM
09/07/10 02:23 PM
Ozona, Texas
P
Paladin Offline
Paladin  Offline
P
Ozona, Texas
For what you described, I would suggest the Lunati Voodoo 60301 camshaft. It has a lot of torque, redlines around 5200 RPM, and pulls about 18 inches of vacuum at idle. Also makes that 440 fairly easy on gas, all things considered.
Definitely stay with the double row timing chain.
May God bless America,
Paladin
1971 Dodge Charger R/T
1977 Chrysler Cordoba A35
1979 Dodge Lil� Red Express
1981 Chevrolet Corvette
1985 Chevrolet Corvette
1986 Chevrolet Corvette Roadster
1994 Lincoln Mark VIII
1998 Dodge Ram 2500 Sport V10
Re: I want to lose my MP cam and crappy idle - suggestions [Re: Paladin] #795416
09/07/10 02:51 PM
09/07/10 02:51 PM
Central NC
gch Offline
gch  Offline
Central NC
Either the comp or lunati 262 grind should give you a smooth idle and plenty of low speed torque for cruising.
Re: I want to lose my MP cam and crappy idle - suggestions [Re: gch] #795417
09/07/10 03:03 PM
09/07/10 03:03 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
What's the initial timing on your car. It makes a HUGE difference in idle profile.
As an example. My 340 has a 284/528 mechanical in it. When the car was at 12* initial, it wouldn't run right at idle unless the AF was in the 12.7 range. Change the initial to 20*, it now idles with an AF of 14.2-14.7, much snappier response too.
Vacuum went for 9's to about 11-12 inches.
Re: I want to lose my MP cam and crappy idle - suggestions [Re: RobX4406] #795418
09/07/10 03:11 PM
09/07/10 03:11 PM
Central IL
70Sbird Offline OP
70Sbird  Offline OP
Central IL
If memory serves me correctly i'm running about 18 degrees
Re: I want to lose my MP cam and crappy idle - suggestions [Re: 70Sbird] #795419
09/07/10 03:53 PM
09/07/10 03:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
First, get someone who knows how to setup your distributer and carb. Then decide if you like the current cam, I bet you will want to keep it.
