70 Duster 340 weight #79468
06/25/08 12:32 PM
06/25/08 12:32 PM
Phila Pa
scatpacktom Offline OP
Phila Pa
What does one weigh? 4sp,man steering,power brakes,bucket seats,no undercoating,no scoops or other frills.Anyone have an idea?
Re: 70 Duster 340 weight [Re: scatpacktom] #79469
06/25/08 01:43 PM
06/25/08 01:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know exactly based on your option list but if you figure 3200-3400 you'll be pretty darn close. If you do some "creative" lightening around 2,900 should be attainable without to much headache.
If you want to built a FAST Duster I'd suggest a 71-72 because of the better TQ carb
*That white 71 was sure running hard to run an 11.66 Must have a well planned and put together small block in that bad boy!
Re: 70 Duster 340 weight [Re: ScottSmith_Harms] #79470
06/25/08 01:45 PM
06/25/08 01:45 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Tom,
My Duster, when it was in the setup you described other than power brakes weighed 3250 at E-town with a full tank of gas and me (220lbs) in it and I wasn't that creative with lightening this car.
That is a 72 but I don't know what would be much different.
Watching Jeff run 11.66 in a Duster got you thinkin'??? That sure is making me itch to put the real motor in......
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: 70 Duster 340 weight [Re: CJK440] #79471
06/25/08 01:47 PM
06/25/08 01:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Tom,
My Duster, when it was in the setup you described weighed 2250 at E-town with a full tank of gas and me (220lbs) in it.
Are you running a carbon fiber body on a tube chassis
Re: 70 Duster 340 weight [Re: ScottSmith_Harms] #79472
06/25/08 01:51 PM
06/25/08 01:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Tom,
Beat me to that one Scott. Ain't no way they are that light without some serious lightening.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 70 Duster 340 weight [Re: ScottSmith_Harms] #79473
06/25/08 01:51 PM
06/25/08 01:51 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Tom,
The body is actually fabric. I completely missed the typo and was wondering why you guys thought that 3250 was that hard to believe.
It was 3300 with the auto in it this spring and that pig of a console I put in, both times I weighed it I had the original spare in the trunk too, still running an untouched monster Autozone battery up front. So there is a little bit more to come out eventually.
Re: 70 Duster 340 weight [Re: CJK440] #79474
06/25/08 01:52 PM
06/25/08 01:52 PM
Upper Midwest
Upper Midwest
Now that sounds more like it>
Re: 70 Duster 340 weight [Re: MoparforLife] #79475
06/25/08 02:07 PM
06/25/08 02:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I sort of figured it was a typo, just poking you with a stick that's all
Re: 70 Duster 340 weight [Re: scatpacktom] #79476
06/25/08 02:25 PM
06/25/08 02:25 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Tom,
My car weighs 3060. I havent done a whole lot of lightening. The trany, converter and fluid probably weigh more than a trick aluminum 4 spd and flywheel.
I did use a sealed lead acid battery, alum driveshaft and lighter drums, but after spending the money there I found I needed to add 230 lbs in the trunk in order to go anywhere on polyglass.
As good as the car runs I think there is alot more someone could do if they were willing to spend the money. The duster is the result of a fairly low buck effort, with almost all the work done at home, things that I'm sure could be done better (like a set of pro ported heads). Also no roller cam.
I think someone could get well below 11.50. Thats another thing, I really dont want to put a roll bar in the car. Although I wouldnt mind having that dilema.
BTW thanks everyone for the compliments.
Re: 70 Duster 340 weight [Re: Rapid340] #79477
06/25/08 03:22 PM
06/25/08 03:22 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
When i got my 70 (auto, bench, factory air)it weighed 3070
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: 70 Duster 340 weight [Re: B3422W5] #79478
06/25/08 04:30 PM
06/25/08 04:30 PM
Phila Pa
Phila Pa
Wow I feel like I can't go out in public anymore.Just a innocent question guys
Jeff your car is really honking,nice job.
Re: 70 Duster 340 weight [Re: scatpacktom] #79479
06/25/08 06:45 PM
06/25/08 06:45 PM
Upper Midwest
Upper Midwest
Not a thing wrong with your question. Just goes to show that weights vary with years and options. On 75 I have the seats out, glass hood, glass front bumper, crash bars in doors removed, crash bumper system junked and bumpers mounted with light 1 inch aluminum strap metal, light weight aluminum racing wheels, add back in 6 point bar and I am down to about 3000 lb race weight with my 135 and full 4 gallon cell in it.
Runs low 11.40's at home track.
