Re: 70 Duster 340 weight
[Re: scatpacktom]
#79469
06/25/08 01:43 PM
06/25/08 01:43 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I don't know exactly based on your option list but if you figure 3200-3400 you'll be pretty darn close. If you do some "creative" lightening around 2,900 should be attainable without to much headache. If you want to built a FAST Duster I'd suggest a 71-72 because of the better TQ carb *That white 71 was sure running hard to run an 11.66 Must have a well planned and put together small block in that bad boy!
[Re: ScottSmith_Harms]
#79470
06/25/08 01:45 PM
06/25/08 01:45 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
Tom,
My Duster, when it was in the setup you described other than power brakes weighed 3250 at E-town with a full tank of gas and me (220lbs) in it and I wasn't that creative with lightening this car.
That is a 72 but I don't know what would be much different.
Watching Jeff run 11.66 in a Duster got you thinkin'??? That sure is making me itch to put the real motor in......
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: CJK440]
#79471
06/25/08 01:47 PM
06/25/08 01:47 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Tom,
My Duster, when it was in the setup you described weighed 2250 at E-town with a full tank of gas and me (220lbs) in it.
Are you running a carbon fiber body on a tube chassis
[Re: scatpacktom]
#79476
06/25/08 02:25 PM
06/25/08 02:25 PM
Posts: 2,091 oberlin, Ohio
Rapid340
oberlin, Ohio
Tom,
My car weighs 3060. I havent done a whole lot of lightening. The trany, converter and fluid probably weigh more than a trick aluminum 4 spd and flywheel.
I did use a sealed lead acid battery, alum driveshaft and lighter drums, but after spending the money there I found I needed to add 230 lbs in the trunk in order to go anywhere on polyglass.
As good as the car runs I think there is alot more someone could do if they were willing to spend the money. The duster is the result of a fairly low buck effort, with almost all the work done at home, things that I'm sure could be done better (like a set of pro ported heads). Also no roller cam.
I think someone could get well below 11.50. Thats another thing, I really dont want to put a roll bar in the car. Although I wouldnt mind having that dilema.
BTW thanks everyone for the compliments.
[Re: Rapid340]
#79477
06/25/08 03:22 PM
06/25/08 03:22 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
When i got my 70 (auto, bench, factory air)it weighed 3070
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: scatpacktom]
#79479
06/25/08 06:45 PM
06/25/08 06:45 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Not a thing wrong with your question. Just goes to show that weights vary with years and options. On 75 I have the seats out, glass hood, glass front bumper, crash bars in doors removed, crash bumper system junked and bumpers mounted with light 1 inch aluminum strap metal, light weight aluminum racing wheels, add back in 6 point bar and I am down to about 3000 lb race weight with my 135 and full 4 gallon cell in it. Runs low 11.40's at home track.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
