Hughes or bullet cam #794477
09/06/10 05:58 PM
09/06/10 05:58 PM
Communist New York State, Comi...
W
We The People Offline OP
W
Due to an out of the block slip up, I am in search of a new cam....don't ask please, I am not to happy with myself.
anyway, the old cam was an 11yr old Ultradyne NF64 .620" 271 @ 50, I liked it in the 446". but now its going to 493" and it will have to breath to about 7000 rpm so maybe upgrading isnt so bad. I was happy with the Ultradyne, but I am wondering if the dual pattern hughes may have some advantages. I was thinking the Hughes cam # hug htl8087bs .633" .644" @1.5 280 287 @ 50, may be a good step up. what do you all think?
493" 1050, ported max wedge indy s/rs 1.5 ratio, 10.5 comp, converter will be sent to Lenny for new combo, 4.56 gears and a 3800 lb car, 29x11 tires. Thanks all
Re: Hughes or bullet cam [Re: We The People] #794478
09/06/10 05:58 PM
09/06/10 05:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Bullet!
Mopar Performance
Re: Hughes or bullet cam [Re: moparniac] #794479
09/06/10 06:35 PM
09/06/10 06:35 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Bullet!
TOTALLY!!!!!!
Re: Hughes or bullet cam [Re: MIKES_DUSTER] #794480
09/06/10 06:45 PM
09/06/10 06:45 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i don't know bullit, but i DO KNOW hughes. i have a 280/287 with 1.6's in a motor. it's the only door car with a flat tappet cam at our local track that runs in the 5's 1/8th. mi. oh yeah, with rpm heads. you figure.
Re: Hughes or bullet cam [Re: tjmarcus1] #794481
09/06/10 07:00 PM
09/06/10 07:00 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Wonder who grinds those "Hughes" cams?
Re: Hughes or bullet cam [Re: goldmember] #794482
09/06/10 07:08 PM
09/06/10 07:08 PM
W
W
I think they may be done by erson, maybe lunati. I cant remeber.
Re: Hughes or bullet cam [Re: We The People] #794483
09/06/10 07:47 PM
09/06/10 07:47 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Bullit
Joey
Re: Hughes or bullet cam [Re: jake4cars] #794484
09/06/10 08:30 PM
09/06/10 08:30 PM
W
W
WoW...I was expecting to start a big debate with this one.
alright then which bullit cam?
Re: Hughes or bullet cam [Re: We The People] #794485
09/06/10 08:33 PM
09/06/10 08:33 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Call Bullitt, tell them your intended use and let them suggest, you will not be disappointed.
Joey
Re: Hughes or bullet cam [Re: We The People] #794486
09/06/10 08:33 PM
09/06/10 08:33 PM
Call Bullet tomorrow and ask for Tim,he's the guy!!!
Re: Hughes or bullet cam [Re: MIKES_DUSTER] #794487
09/06/10 08:39 PM
09/06/10 08:39 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Bullet all the way!!
We had a custom made cam for our motor and it worked great.
They picked it out and everything!
Re: Hughes or bullet cam [Re: HEMIDARTS] #794488
09/06/10 09:36 PM
09/06/10 09:36 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Nother vote for Tim @ Bullet. Spec-ed a solid for our bracket motor, it shipped the same day he said it would and it runs pretty good, too!
Re: Hughes or bullet cam [Re: We The People] #794489
09/06/10 09:56 PM
09/06/10 09:56 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Hughes cams are pretty hard to beat, ran several (hyd and solid) and had good results. They make good torque and help the car to et
Re: Hughes or bullet cam [Re: tjmarcus1] #794490
09/06/10 10:14 PM
09/06/10 10:14 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
again, how many of the "bullitt" boys are in the 5's with a flat tappet cam and rpm heads?
Re: Hughes or bullet cam [Re: tjmarcus1] #794491
09/06/10 10:24 PM
09/06/10 10:24 PM
W
W
ahhh here we go!
Re: Hughes or bullet cam [Re: We The People] #794492
09/06/10 10:33 PM
09/06/10 10:33 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
ahhh here we go!
Re: Hughes or bullet cam [Re: goldmember] #794493
09/06/10 11:25 PM
09/06/10 11:25 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Hughes or bullet cam [Re: Adobedude] #794494
09/07/10 10:47 AM
09/07/10 10:47 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Not sure about the Flat Tappets anymore but I'm pretty sure all of Hughes Hyd Roller stuff are Bullet grinds.
The Hughes Flat Taps that were done by Engle back in the 90's were all really good lobes, I ran a lot of them without complaint.
WIZE
In Car:
Re: Hughes or bullet cam [Re: Streetwize] #794495
09/07/10 11:13 AM
09/07/10 11:13 AM
W
W
yes , Engle.....I said earson ...Knew it was an E name.
so now its pretty close between, the two...anyone else? They must both be pretty good, with such a loyal following.
thanks guys
Re: Hughes or bullet cam [Re: We The People] #794496
09/07/10 11:22 AM
09/07/10 11:22 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you go w/ a Hughes grind, I'd suggest no bigger than the 276/280 because of your low CR.
No idea who actually grinds their flat-tappet cams after they stopped using Engle years ago, though.
