FRONT TIRES ON A DUSTER #794377
09/06/10 02:36 PM
09/06/10 02:36 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Right now I run 26"x4.5 M/T Frontrunners on my 72 stock suspension SB duster. I was thinking of going with either a 27" or 27.5" tire and a friend of mine said that he didnt think I could run that tall without working the fenders.
What are you guys running??
Re: FRONT TIRES ON A DUSTER [Re: MIKES_DUSTER] #794378
09/06/10 03:16 PM
09/06/10 03:16 PM
Locomotion Offline
Locomotion  Offline
This may have been discussed before, but..........
I have 28" Hoosiers on my Dart Sport. I did have to bend the bottom corner lip of the wheel opening at the front and the tires may scuff a bit on bumps during turns.
Wheel offset and suspension height may be factors also.
Don't have any close-ups. But they fill the openings up nicely. I went to the taller tires based on reaction times.
Re: FRONT TIRES ON A DUSTER [Re: Locomotion] #794379
09/06/10 06:36 PM
09/06/10 06:36 PM
Anyone else???
Re: FRONT TIRES ON A DUSTER [Re: MIKES_DUSTER] #794380
09/06/10 06:46 PM
09/06/10 06:46 PM
az
stage3 Offline
stage3  Offline
az
I had 29" moroso's on my stock elim. Duster with a little trimming on the front. Really depends on how low you want the front end.
Re: FRONT TIRES ON A DUSTER [Re: MIKES_DUSTER] #794381
09/07/10 12:51 AM
09/07/10 12:51 AM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
I just tried to do this myself. 71 duster with uncut front fenders. I run the 26 inch M/T and when i put the 27.5 on they hit the rear lower point of the fender lip. So, I put the 26's back on.
Re: FRONT TIRES ON A DUSTER [Re: Plumcrazyracing] #794382
09/07/10 08:50 AM
09/07/10 08:50 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Mike I run 26's but I know I can go to a 27 no problem at all. 493_John gave me a good pointer... a lot of dusters are not consistent side to side. Take a second and check yours. Does the tire fall in the same spot in the wheel well opening on both sides. On my car, the passenger tire is way closer to the rear of the opening then the drivers side. I also notice, the lower the front end the easier it is to get the taller tire in there
Re: FRONT TIRES ON A DUSTER [Re: joshking440] #794383
09/07/10 12:11 PM
09/07/10 12:11 PM
Thanks guys!!!! I will try to do some measurments today.
Re: FRONT TIRES ON A DUSTER [Re: MIKES_DUSTER] #794384
09/15/10 04:07 PM
09/15/10 04:07 PM
