fuel cell #793841
09/05/10 09:54 PM
09/05/10 09:54 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
just wondering if there is a way to clean the inside of a fuel cell asking because the car i bought been sitting in my garage for 1 yr maybe been sitting else were longer 8 gal w/foam..........Thanks 4 the help
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: fuel cell [Re: 67mprfan] #793842
09/05/10 10:01 PM
09/05/10 10:01 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
You can pull all the foam out and clean the inside with water or solvent. I would remove the cell from the car and flush it out. Summit sells new foam if the old stuff is crumbling.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: fuel cell [Re: Dads426] #793843
09/06/10 12:50 AM
09/06/10 12:50 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
can you post some pics of your fuel cell setups
1.39 9.85 - 137 mph
Re: fuel cell [Re: Ari440] #793844
09/06/10 10:40 PM
09/06/10 10:40 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
trunk view
Re: fuel cell [Re: 67mprfan] #793845
09/06/10 10:41 PM
09/06/10 10:41 PM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
under the car
Re: fuel cell [Re: 67mprfan] #793846
09/06/10 10:47 PM
09/06/10 10:47 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
That is the same tank I have. Pull the ring off then pull the foam out. If in good shape, reuse it. As stated earlier, take the tank out and wash it out. Reinstall foam and you're good to go!
Re: fuel cell [Re: markz528] #793847
09/09/10 02:53 AM
09/09/10 02:53 AM
ohio
67mprfan Offline OP
67mprfan  Offline OP
ohio
Wow i pulled the foam out last nite and today my garage smells like old rotten eggs.
Re: fuel cell [Re: 67mprfan] #793848
09/09/10 03:13 AM
09/09/10 03:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm waiting for my new fuel cell to arrive. It was so old it finally cracked in several places. I'm sure living where it bakes in the trailer didn't help in that area at all.
