Console door nuts and studs #793600
09/05/10 07:01 PM
09/05/10 07:01 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I cant tighten the nuts on the studs in the console hinge.Either the studs are stripped or the nuts are shot.I tried to pry the inside of the nuts closed ,but they are stiff.Do the studs screw out???Where would you get new ones??Thanks
Re: Console door nuts and studs [Re: 70RR383] #793601
09/06/10 09:43 AM
09/06/10 09:43 AM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
I sent a couple of messages to supliers of the new consols,hope this helps,anybody??I cant be the only one with this problem.
Re: Console door nuts and studs [Re: 70RR383] #793602
09/06/10 06:32 PM
09/06/10 06:32 PM
New Zealand
dart6 Offline
dart6  Offline
New Zealand
yes i would like to know too
Re: Console door nuts and studs [Re: dart6] #793603
09/06/10 06:37 PM
09/06/10 06:37 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Dante says NOT AVALABLE.Do they unscrew??If so,I am sure I could find a stud or make one.
Re: Console door nuts and studs [Re: 70RR383] #793604
09/08/10 05:34 PM
09/08/10 05:34 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
New console lid studs are smaller in diameter than originals and do not take original style nuts. I ended up going thru my spare tinnerman nut selection and found a set of smaller, flatter nuts that I was able to make work. For the amount of money these parts bring, you would think that this most important detail would not be missed. I was not particularly thrilled with the fact that I had to set aside original hardware and go with a less than appealing plan B to install my new lid.
Re: Console door nuts and studs [Re: 70mopes] #793605
09/08/10 11:24 PM
09/08/10 11:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Try McMaster-Carr - they have a website, are very reasonable, and ship very quickly.
My guess is the thread size is smaller on the new parts, or your fasteners were over-tightened at some point and their threads are stripped.
