replacement shrader valves for A/C lines?
#793342
09/05/10 12:56 PM
09/05/10 12:56 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
My 92 D250 seems to be leaking from the low side shrader valve. I converted to 134A six or seven years ago. I've had a slow leak that has been very difficult to chase down. When I pulled the cap off the valve last time all kinds of leak detection dye ran out. is it possible to replace the valve or are the screw on conversion caps likely to blame?
Re: replacement shrader valves for A/C lines?
[Re: stumpy]
#793344
09/05/10 01:09 PM
09/05/10 01:09 PM
feets
Senior Management
Senior Management
Irving, TX
I haven't done that yet. I didn't want to mess with it while it was still cooling. It's not cooling now so it's okay to play with it.
[Re: DTM_Motorsports]
#793346
09/05/10 04:46 PM
09/05/10 04:46 PM
feets
Senior Management
Senior Management
Irving, TX
Are they the same as tire valves? I thought they'd be a different size.
[Re: feets]
#793347
09/05/10 09:06 PM
09/05/10 09:06 PM
Posts: 1,012 indiana
mcmopars
indiana
they have a tool that changes the core without removing the freon
1961 chrysler
1973 duster
1998 ram
2005magnum
2010ram
[Re: feets]
#793348
09/06/10 02:17 AM
09/06/10 02:17 AM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
There are a/c specific valve cores, but I have seen regular tire valves used on occasion.
[Re: JeffC]
#793349
09/06/10 02:29 AM
09/06/10 02:29 AM
Posts: 21,523 N.E. OHIO, USA
A12
N.E. OHIO, USA
What or why would they be different than a tire valve core? I pulled them out of my system and I'd swear they (looked) are the same as a tire valve core.........they could have been changed by someone that didn't know huh
[Re: A12]
#793351
09/06/10 11:34 AM
09/06/10 11:34 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Some of them are larger than tire valves.I probally have some of the assembleys in the garage from conversions.Feets Id try snugging it.Ive done it hundreds of times at work.Ive also used tire valves a few times.Never had a problem.Rocky
Chrysler Firepower
[Re: therocks]
#793352
09/06/10 12:21 PM
09/06/10 12:21 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
The R 12 cores are similar if not the same as a tire core but the R 134 cores are larger and infact take a different tool.
[Re: mcmopars]
#793354
09/06/10 05:57 PM
09/06/10 05:57 PM
Posts: 84 Santa Fe,Texas
TexasMopar
Santa Fe,Texas
Where do you get this tool? This question is for MCMOPARS.
[Re: WILD BILL]
#793355
09/06/10 06:01 PM
09/06/10 06:01 PM
Challenger 1
Cincinnati, Ohio
Fact, they are available from auto parts stores, tool and the cores.
