Largest tire to run on A body Stock 14 inch wheel #79228
06/24/08 04:30 PM
06/24/08 04:30 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Whats the largest tire I can run on a stock 14 inch wheel on a bone stock A body(72 Swinger)
What is the best looking tire combo for this vehicle on stock 14 inch steel wheels and dogdish hubcaps.
Re: Largest tire to run on A body Stock 14 inch wheel [Re: SPWC] #79229
06/24/08 07:34 PM
06/24/08 07:34 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
4.5" or 5.5" width?
vm
Re: Largest tire to run on A body Stock 14 inch wheel [Re: vynn3] #79230
06/24/08 08:00 PM
06/24/08 08:00 PM
SPWC Offline OP
SPWC  Offline OP
Really unsure of exactly what width wheel
Re: Largest tire to run on A body Stock 14 inch wheel [Re: SPWC] #79231
06/25/08 01:06 PM
06/25/08 01:06 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
If you have Rallyes, they are 5.5" wide. Most steel wheels for A bodies are only 4.5" wide.
I have a 225-70-14 on my stock Rallyes. 71 Dart. Fits good. I wouldnt go any bigger then that.
Re: Largest tire to run on A body Stock 14 inch wheel [Re: SPWC] #79232
06/25/08 02:22 PM
06/25/08 02:22 PM
Texas
vynn3 Offline
vynn3  Offline
Texas
You really need to figure that out first, rather than just guessing on a tire size.
Most tire sellers have calipers that can measure your current wheel width for free. Then you can go from there, using information here or at www.tirerack.com . They list the wheel width range for most tires.
vm
Re: Largest tire to run on A body Stock 14 inch wheel [Re: AdamR] #79233
06/25/08 02:29 PM
06/25/08 02:29 PM
340 A bodies had 5.5 inch wide steelies, otherwise unless you have ralleys, you've almost surely got 4.5 inch wide wheels. Pretty narrow, 205's about as wide a tire as you'd want to go.
Easy to tell the difference, the 5.5 hub is more deeply set into the rim, 4.5 is obviously shallower:
Re: Largest tire to run on A body Stock 14 inch wheel [Re: AdamR] #79234
06/25/08 02:29 PM
06/25/08 02:29 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
That seems a little wide on a 5.5" rim....
I have 7" rims on my Swinger and have 215" on the back with a rolled quarter lip. Still have to play
games to change the dang tire so i can get it off the axle.
Re: Largest tire to run on A body Stock 14 inch wheel [Re: Dart 340] #79235
06/25/08 02:38 PM
06/25/08 02:38 PM
Jack it up, set jackstands under the frame, let the axle drop, and THEN take off the wheel/tire.
Re: Largest tire to run on A body Stock 14 inch wheel #79236
06/25/08 05:26 PM
06/25/08 05:26 PM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
I run 15x7 custom sbp ralley with 245 60 bfg's and they fit stock wheel lip no problem.
Re: Largest tire to run on A body Stock 14 inch wheel [Re: marklock] #79237
06/25/08 07:11 PM
06/25/08 07:11 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
RAn 225s on 5.5 Rallyes years ago on a 67, don't remember any problems what so ever and I didn't roll the wheel well lip.
Great advice about the quick refernce from the outer rim ledge.
Careful, your character's showing!
Re: Largest tire to run on A body Stock 14 inch wheel [Re: mopar346] #79238
06/25/08 07:58 PM
06/25/08 07:58 PM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
245/60s on my 14 rallys on 73 Duster.Not for sure what the rim width was.
