Re: Largest tire to run on A body Stock 14 inch wheel
[Re: SPWC]
#79229
06/24/08 07:34 PM
06/24/08 07:34 PM
Posts: 411 Texas
vynn3
Texas
[Re: AdamR]
#79233
06/25/08 02:29 PM
06/25/08 02:29 PM
340 A bodies had 5.5 inch wide steelies, otherwise unless you have ralleys, you've almost surely got 4.5 inch wide wheels. Pretty narrow, 205's about as wide a tire as you'd want to go. Easy to tell the difference, the 5.5 hub is more deeply set into the rim, 4.5 is obviously shallower:
[Re: AdamR]
#79234
06/25/08 02:29 PM
06/25/08 02:29 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
If you have Rallyes, they are 5.5" wide. Most steel wheels for A bodies are only 4.5" wide.
I have a 225-70-14 on my stock Rallyes. 71 Dart. Fits good. I wouldnt go any bigger then that.
That seems a little wide on a 5.5" rim.... I have 7" rims on my Swinger and have 215" on the back with a rolled quarter lip. Still have to play games to change the dang tire so i can get it off the axle.
[Re: Dart 340]
#79235
06/25/08 02:38 PM
06/25/08 02:38 PM
Jack it up, set jackstands under the frame, let the axle drop, and THEN take off the wheel/tire.
[Re: marklock]
#79237
06/25/08 07:11 PM
06/25/08 07:11 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
RAn 225s on 5.5 Rallyes years ago on a 67, don't remember any problems what so ever and I didn't roll the wheel well lip. Great advice about the quick refernce from the outer rim ledge.
Careful, your character's showing!
