Can't 60ft, any suggestions (slips attached) #792136
09/04/10 01:57 AM
09/04/10 01:57 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Last time I was at the track was in 2008 and my best 60ft was 1.487 and best ET was 9.747. I've made several mods, some added weight and some performance such as
1)New rear strange coil overs
2)New larger rear tires was 32x14.5 now 33x22.5
3)New wheels, had drag lights now alumastars
4)Had aluminum dash now has a factory dash
5)Had a lexan windshield now has glass
6)Had a cowl scoop now an open aero hood scoop
5)Added a flexplate cover
6)Added a chute
7)Fuel gauge on the fender
8)Added real head lights had simulated aluminum
So I've added some weight but the car scales at 2880 with me in it today. I was hoping the new larger tires and rear shocks would help my 60ft times but nope. Track prep was also not the best tonight. I'm planning to run tomorrow and next weekend to see if it's the same but I should be in the high 1.3's. I'm running 4:56 gears so when I went up to the 33in tire should I consider going up to 4:88 gears to help the torque? I've attached my log so you can see the difference from 2008 until 2010. I didn't get a new torque converter yet either. Gears or Converter if I need to help getting out of the hole? Sorry this is so damn long. Had a great time finally getting out again. Too bad it's September when I started racing this year. Any suggestions for getting out of the hole and staying in the 9's without removing the windshield and dash is appreciated.
Adam
6176855-DragLogBook.xls (132 downloads)
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792137
09/04/10 02:03 AM
09/04/10 02:03 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Here's the actual slips. Sorry for sleeping on the tree but I had to knock the cob webs off.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792138
09/04/10 02:53 AM
09/04/10 02:53 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Your attachments arent working care to just post the times for us? 8th mile e/t and mph too!
Re: Can't 60ft, any suggestions (slips attached) [Re: Bob_Coomer] #792139
09/04/10 03:00 AM
09/04/10 03:00 AM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Thanks Bob. I'll post them in the morning.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792140
09/04/10 03:13 AM
09/04/10 03:13 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
6)Added a chute
Adam
Um, planning on giving us a body style, engine, trans, etc to work with. Because that 60' is way off for a big block with a 'Flite, but not so bad for a small block and a 'Glide.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Can't 60ft, any suggestions (slips attached) [Re: Evil Spirit] #792141
09/04/10 04:10 AM
09/04/10 04:10 AM
Q
Quicktree Offline
Quicktree  Offline
Q
if it's not spinning I would be looking at the converter, timing,cam timing. my 60' is in the 1.44s and im only running 10.40s 200lbs heavier than you.
Re: Can't 60ft, any suggestions (slips attached) [Re: Quicktree] #792142
09/04/10 10:54 AM
09/04/10 10:54 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I'd buy the next round of drinks for everybody if I could get my tank to 1.487.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792143
09/04/10 11:13 AM
09/04/10 11:13 AM
NC
440Jim Offline
440Jim  Offline
NC
For those that can't see his Excel attachment, Attached is a screen shot of his logbook for the recent runs .
The 2008 runs show better air, so they should be faster... and they are. From the difference in sixty foot between the two runs on 9-3-2010, it looks like it might be spinning the tires, so chassis work/tuning may be in order.
Re: Can't 60ft, any suggestions (slips attached) [Re: 440Jim] #792144
09/04/10 02:37 PM
09/04/10 02:37 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Thanks Jim. It's 72 Cuda, tube chassis, 500ci, 727TF, Indy tunnel, it pulls hard on the top end. Lots of humidity last night so I'm not going to do any drastic changes until I get some more runs in this month. The converter is the same from the previous owner (5500 TCI converter w/ Trans King valve body), I never changed it when I dropped my new motor in. Weight was 2749 with driver prior to my mods. Now it’s 2880 so I’ve added 131 lbs. I’m running 34 deg of timing. I was alone so I couldn't get any video of the launch. I may have broken loose but if I did it wasn't excessive. Just doesn't feel like the front end wants to jump up or rear to squat like it should? I have not touched the 4 link since it was at the chassis shop.
I'm trying to figure out how to post a screen shot like Jim did with all my times. You have to open with Excel.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792145
09/04/10 03:01 PM
09/04/10 03:01 PM
Auburn, Indiana
The Duster Offline
The Duster  Offline
Auburn, Indiana
For Windows, hit print screen or if you only want the active window (not full screen), hit Alt print screen, and the image will be in your clipboard. Just paste.
You will probably need to resize first.
Re: Can't 60ft, any suggestions (slips attached) [Re: The Duster] #792146
09/04/10 03:56 PM
09/04/10 03:56 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Here's an attempt at attaching a jpg of some runs from 2008 to compare.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792147
09/04/10 04:14 PM
09/04/10 04:14 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Really need to know if the tires were spinning or dead hooked. Dead hooking does not always equal a better short time. Without some video we're all just guessing.
Re: Can't 60ft, any suggestions (slips attached) [Re: BobR] #792148
09/04/10 04:46 PM
09/04/10 04:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what size TCI? imo the TCI is not a quality converter. thats the first place I would be concerned with. and I bet you get 10 people saying their's is fine
Re: Can't 60ft, any suggestions (slips attached) [Re: Quicktree] #792149
09/04/10 05:04 PM
09/04/10 05:04 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
I've been putting off getting a new converter but I never really heard pros or cons to the TCI brand. It's an 8 inch converter but I've been planning to pick up a Coan converter over the winter that's custom built for my engine specs based on my time slips. Sorry but I'm a loner, no one to video any of the runs for me I'd love to be able to see what the rear tires are doing compared to how it feels in the car. I'll see if I can beg someone to come to the track and get some footage. Sounds like that's probably step 1.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792150
09/04/10 10:21 PM
09/04/10 10:21 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
With those 60's being all over the place I would be looking into learning about your 4 link setup and your shock set ups. That thing is not working. Even if the converter was not for your combo it still would at least be consistent.
JAKES AUTOMOTIVE
Re: Can't 60ft, any suggestions (slips attached) [Re: JAKE68] #792151
09/05/10 10:56 PM
09/05/10 10:56 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Should I start with the front shock settings? Set the front shocks to the softest dampning settings and leave the rears as is and see what happens? If the front doesn't react quick enough by popping up on launch then I'll start adjusting the rears to a softer setting as well. It just seems like the suspension is too stiff and not a quick extension for take off. Then 4 link last.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792152
09/05/10 11:32 PM
09/05/10 11:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It all starts with the rear and if your 4 link is all
wrong ... well it wont do anything... back first
then the front has to transfer to keep the back
planted... what is your IC length and height
Re: Can't 60ft, any suggestions (slips attached) [Re: MR_P_BODY] #792153
09/06/10 08:38 PM
09/06/10 08:38 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
Just got the car back from a professional chassis shop. They put new rear coil overs on as requested, scaled the car, and adjusted the pinion angle. I'm sure the 4 link is close and the shocks/tire pressure is more of the issue. I'll jack it up and find the C of G and then measure from the rear tires to get my numbers and double check the 4 link settings.
Re: Can't 60ft, any suggestions (slips attached) [Re: Big_Fish] #792154
09/06/10 08:51 PM
09/06/10 08:51 PM
Pennsylvania, USA
Big_Fish Offline OP
Big_Fish  Offline OP
Pennsylvania, USA
This seems to be a good reference for what I'm using to find my measurements for initial settings (Instant Center etc). http://www.motorsportsvillage.com/suspension1.html
