Re: Popping sound coming from front end?
[Re: Pntastar69]
#79197
06/24/08 03:01 PM
06/24/08 03:01 PM
Posts: 1,385 Ohio
rck850
Ohio
Rubber or poly bushings? I'll bet on poly.
Actually it was a stock rebuild so I went with rubber. Thanks I will check the UCA bushings and also the other bolted connections.
[Re: rck850]
#79198
06/24/08 03:40 PM
06/24/08 03:40 PM
Check your A-Arm Bolts. I left one loose after my build and it was doing the same thing.
[Re: rck850]
#79201
06/24/08 04:26 PM
06/24/08 04:26 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
Well most of the noise disappeared when I tightened the UCA bolts btw what is the torque spec on the nuts that hold the UCA on the piviot bar? I have never replaced the bushings between the K frame and the front subframe as far as I know they are not even being reproduced. Mine look fine though and have very few dry cracks in them.
the fact that they have any dry cracks in them means they need to be replaced , you can get a solid spacer to replace the bushing . have you actually gone to the auto parts store and ASKED for them ? i would be surprised if they aren't still available .
oh and get a factory service manual while you are at it , they are invaluable
[Re: scratchnfotraction]
#79203
06/24/08 04:46 PM
06/24/08 04:46 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Burred-up or dry torsion bar ends can cause that also, though it's usually more of a 'pop' and a 'ping' sound at the same time.
Rich H.
Esse Quam Videri
[Re: rck850]
#79206
06/25/08 11:11 AM
06/25/08 11:11 AM
Posts: 553 LA & L.A.
MoparPosterChild
LA & L.A.
Have you noticed if it happens most of the time when you are applying the brakes? Or just regular driving that involves suspension travel?
2018 Dodge DEMON #18 1970 Plymouth Duster 406" Stroker 1969 Charger 500" Stroker 1964 Dodge Polara 426 GEN III HEMI 1970 Plymouth Cuda Hellcrate Project car 1974 Dodge Ramcharger Project car 2017 Chrysler Pacifica Limited 2017 Ram 3500 2012 Dodge Caravan R/T 1972 Charger Mopar 392 HEMI Stolen 2008 Challenger SRT-8 Gone 2010 Challenger SRT-8 Gone 2006 Charger SRT-8 Gone 2007 Charger R/T Gone
[Re: lewtot184]
#79208
06/25/08 01:04 PM
06/25/08 01:04 PM
Posts: 3,054 USA
b54406barrel
USA
try lubricating the pivot point of the strut rod at the lower control arm.
That's a definite possibility. My blue car started doing that in the mid-70's, especially when driving over a rise & then coming back down. The service manager @ the C-P dealer told me to blow some graphite into that point & that took care of it.
