Well most of the noise disappeared when I tightened the UCA bolts btw what is the torque spec on the nuts that hold the UCA on the piviot bar? I have never replaced the bushings between the K frame and the front subframe as far as I know they are not even being reproduced. Mine look fine though and have very few dry cracks in them.
the fact that they have any dry cracks in them means they need to be replaced , you can get a solid spacer to replace the bushing . have you actually gone to the auto parts store and ASKED for them ? i would be surprised if they aren't still available .
oh and get a factory service manual while you are at it , they are invaluable
