where should it be located the map light on a 70 dart ? #79183
06/24/08 02:10 PM
06/24/08 02:10 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
what you read!!
Re: where should it be located the map light on a 70 dart ? [Re: NachoRT74] #79184
06/24/08 07:16 PM
06/24/08 07:16 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Under the bottom lip of the dash, on the far right hand side.
Re: where should it be located the map light on a 70 da [Re: In_The_Pink] #79185
06/25/08 10:34 AM
06/25/08 10:34 AM
Valencia, España
Valencia, España
so practically on center on dash ? but on dash pad or dash frame ?
sorry, I'm not in A bodies, just asking to a buddy with a swinger. we found does have the map light switch don the dash frame, but can't find a map light around
Re: where should it be located the map light on a 70 da [Re: NachoRT74] #79186
06/25/08 10:37 AM
06/25/08 10:37 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Under the dash frame at the bottom way over on the passenger side near the corner.
Re: where should it be located the map light on a 70 da [Re: stumpy] #79187
06/25/08 10:57 AM
06/25/08 10:57 AM
Valencia, España
Valencia, España
DAMN!!! THAT FAR AWAY FROM DRIVER ? MAP LIGHT FOR PASSENGER FEET? LOL... will check
Re: where should it be located the map light on a 70 da [Re: NachoRT74] #79188
06/25/08 11:53 AM
06/25/08 11:53 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Yep, I have an original 70 swinger 340 with the light in it. I can send a photo if you would like.
Re: where should it be located the map light on a 70 da [Re: Dart 340] #79189
06/25/08 12:49 PM
06/25/08 12:49 PM
Grand Prairie,Texas
Grand Prairie,Texas
THe idea was to have the passenger read the map while the driver kept his eyes on the road and to keep the light from interfering with the drivers night sight.
Re: where should it be located the map light on a 70 da [Re: stumpy] #79190
06/25/08 01:05 PM
06/25/08 01:05 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I have to agree with Richard on this one. It was a
good placement. I have thought about adding a second
one on the drivers side but it is a bright light.
Re: where should it be located the map light on a 70 da [Re: Dart 340] #79191
06/25/08 01:57 PM
06/25/08 01:57 PM
Valencia, España
Valencia, España
yeah definitelly would like a pic!!!
and what about if you don't have a passenger on car ? LOL
I love the B body locations... 70s above the cluster and 60s above the Radio
Re: where should it be located the map light on a 70 da [Re: NachoRT74] #79192
06/25/08 02:04 PM
06/25/08 02:04 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Let me tell you, it will still be bright enough!
Re: where should it be located the map light on a 70 da [Re: Dart 340] #79193
06/25/08 09:24 PM
06/25/08 09:24 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Here's a pic of a map light removed from a '72 Scamp:
