are slant 6s interferance fit engines? #791686
09/03/10 02:50 PM
09/03/10 02:50 PM
Springfield Oregon
badblubeee Offline OP
super gas
super gas
Springfield Oregon
The timing gears broke/slipped on my 76 Duster 225 slant 6 and I'm wondering if the valves hit the pistons.I don,t want to put a new chain and gears in and find that the valves are junk.Dave
Re: are slant 6s interferance fit engines? [Re: badblubeee] #791687
09/03/10 05:25 PM
09/03/10 05:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
No they are not interference engines. Just replace the gears and chain.
Re: are slant 6s interferance fit engines? [Re: stumpy] #791688
09/03/10 05:39 PM
09/03/10 05:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Be smart to check it out. I have seen an awful lot of bent valves and eye brows on pistons in Mopar's 'non interference' engine over the years when the sprocket or chain goes south..
Re: are slant 6s interferance fit engines? [Re: MoparforLife] #791689
09/03/10 06:56 PM
09/03/10 06:56 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
If it's a stock motor the pistons are at least .150" down in the hole. You'd really have to do something fantastic to hit the valves.
Re: are slant 6s interferance fit engines? [Re: badblubeee] #791690
09/04/10 01:45 AM
09/04/10 01:45 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I had the timing gears break apart and the chain slip on the 225 in my old 69 Valiant. I didn't check for bent valves, just put in a new timing chain set, and it ran fine for years, and still ran fine when I sold it.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: are slant 6s interferance fit engines? [Re: Evil Monkey] #791691
09/04/10 08:09 AM
09/04/10 08:09 AM
Upper Midwest
Upper Midwest
On /6 it would be very rare if at all. all I said is that it wouldn't hurt to check.
Re: are slant 6s interferance fit engines? [Re: MoparforLife] #791692
09/04/10 02:43 PM
09/04/10 02:43 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
broke mine, and NP, i think you will be ok, the pistons are way down in the hole..
Re: are slant 6s interferance fit engines? [Re: MoparforLife] #791693
09/04/10 02:48 PM
09/04/10 02:48 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not everyone has the extra money and time to tear the top off an engine just because. I have never seen a stock leaning tower of power bend a valve because of a timing chain failure and I've been doing this stuff for 45 years.
Re: are slant 6s interferance fit engines? [Re: stumpy] #791694
09/04/10 07:40 PM
09/04/10 07:40 PM
Park Forest, IL
slantzilla Offline
Park Forest, IL
At stock lift the valve heads barely clear the top of the chamber if at all. Net lift is less than .400", the chamber is pretty close to that deep itself.
With the pistons at -.020" in mine I didn't even have to cut valve reliefs until I went to a .558" lift cam and put 1.6 rockers on it.
Re: are slant 6s interferance fit engines? [Re: stumpy] #791695
09/04/10 09:13 PM
09/04/10 09:13 PM
Upper Midwest
Upper Midwest
Like I said it would be a real rarity if it happened with a /6. In fact if our mechanics would have had to make a living working on /6's they would have starved to death in a real hurry. They were so close to bullet proof it was scary.
Re: are slant 6s interferance fit engines? [Re: MoparforLife] #791696
09/04/10 11:06 PM
09/04/10 11:06 PM
Springfield Oregon
super gas
super gas
Springfield Oregon
Hey, thanks for all the replys. I didn't do anything wild to make this happen-I just parked in the garage,turned it off and later when I tried starting it it just spun over real good(cause open valves) and wouldn't fire -
I had this happen years ago on my 69 RR and after replacing the gears and chain it ran on 5 holes.
I've had about a dozen different slants and this is the first internal failure and this car had a easy life so ya just never know Dave
