Re: are slant 6s interferance fit engines?
[Re: badblubeee]
#791690
09/04/10 01:45 AM
09/04/10 01:45 AM
Posts: 357 Lake Elmo, MN
Evil Monkey
Lake Elmo, MN
I had the timing gears break apart and the chain slip on the 225 in my old 69 Valiant. I didn't check for bent valves, just put in a new timing chain set, and it ran fine for years, and still ran fine when I sold it.
1974 'Cuda 360/TKO
1990 Ram Van
1998 Neon
[Re: MoparforLife]
#791693
09/04/10 02:48 PM
09/04/10 02:48 PM
Posts: 32,937 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
On /6 it would be very rare if at all. all I said is that it wouldn't hurt to check.
Not everyone has the extra money and time to tear the top off an engine just because. I have never seen a stock leaning tower of power bend a valve because of a timing chain failure and I've been doing this stuff for 45 years.
[Re: stumpy]
#791694
09/04/10 07:40 PM
09/04/10 07:40 PM
Posts: 20,182 Park Forest, IL
slantzilla
Park Forest, IL
At stock lift the valve heads barely clear the top of the chamber if at all. Net lift is less than .400", the chamber is pretty close to that deep itself. With the pistons at -.020" in mine I didn't even have to cut valve reliefs until I went to a .558" lift cam and put 1.6 rockers on it.
[Re: stumpy]
#791695
09/04/10 09:13 PM
09/04/10 09:13 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Like I said it would be a real rarity if it happened with a /6. In fact if our mechanics would have had to make a living working on /6's they would have starved to death in a real hurry. They were so close to bullet proof it was scary.
[Re: MoparforLife]
#791696
09/04/10 11:06 PM
09/04/10 11:06 PM
Posts: 1,780 Springfield Oregon
badblubeee
super gas
super gas
Springfield Oregon
Hey, thanks for all the replys. I didn't do anything wild to make this happen-I just parked in the garage,turned it off and later when I tried starting it it just spun over real good(cause open valves) and wouldn't fire - I had this happen years ago on my 69 RR and after replacing the gears and chain it ran on 5 holes. I've had about a dozen different slants and this is the first internal failure and this car had a easy life so ya just never know Dave
