Challenger Brake clutch pedal install question #791632
09/03/10 11:56 AM
09/03/10 11:56 AM
Omaha
road Offline OP
road  Offline OP
Omaha
Installing the brake - clutch pedals on a 73 challenger and have a question on attaching to the firewall. Are there any additional bolts used other than the 4 from the power booster? When I took it off (many any years ago) I put 4 bolts and nuts on the assembly where it attaches to the firewall. Service and parts manual appear to only use the booster bolts.
Re: Challenger Brake clutch pedal install question [Re: road] #791633
09/03/10 12:46 PM
09/03/10 12:46 PM
Fremont, CA.
Topcat Offline
Topcat  Offline
Fremont, CA.
The support bracket located to the left also.
Re: Challenger Brake clutch pedal install question [Re: Topcat] #791634
09/03/10 03:47 PM
09/03/10 03:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Correct - there should also be the little support bracket for 4 speed cars.
Re: Challenger Brake clutch pedal install question [Re: Morty426] #791635
09/03/10 06:50 PM
09/03/10 06:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The firewall brace
Re: Challenger Brake clutch pedal install question [Re: DAYCLONA] #791636
09/03/10 06:53 PM
09/03/10 06:53 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
This may help,.....the 2 holes you need to drill are just dimples now on your firewall, just drill the dimples to locate the 4 spd pedal bracket
Mike
