Blocking off fuel sender return line w/cap #79101
06/24/08 09:38 AM
06/24/08 09:38 AM
Indiana
W5Duster436 Offline OP
Indiana
Does anybody know if there are 5/16" caps for sending units?
My car only has a 3/8" fuel line and I purchased a 3/8 sending unit from Mancini and it has a return line fitting on it. I didn't want to stick a piece of hose with a bolt in it etc. and wondered if anyone makes a cap that will withstand fuel?
Re: Blocking off fuel sender return line w/cap [Re: W5Duster436] #79102
06/24/08 10:29 AM
06/24/08 10:29 AM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
I used a vacuum cap on mine. Been working quite well for some time now. No leakage.
Re: Blocking off fuel sender return line w/cap [Re: Dart 340] #79103
06/24/08 11:12 AM
06/24/08 11:12 AM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I agree, A vacuum plug should be fine. That return line shouldn't be continously subjected to liquid fuel to the point it will "eat it" away. Just check it every year or so for deterioration...
Re: Blocking off fuel sender return line w/cap [Re: W5Duster436] #79104
06/24/08 11:19 AM
06/24/08 11:19 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If you have not installed the new one yet, just weld or solder it shut?
Re: Blocking off fuel sender return line w/cap [Re: OzHemi] #79105
06/24/08 11:26 AM
06/24/08 11:26 AM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
mine reads off so I might do that when I take it out and bend the arm. It is stainless though so it might be a pain. With the old style venting on mine it does not build up any pressure at all in the tank so the vacuum cap has been good to me.
Re: Blocking off fuel sender return line w/cap [Re: Dart 340] #79106
06/24/08 11:53 AM
06/24/08 11:53 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
The return line is a really nice feature to have, it keeps the fuel recirculating and cooler + it allows the fuel pump to operate close to peak efficiency...if there aren't any big concerns about originality I'd consider retrofitting a full return system, it'll make a better car
Rich H.
Esse Quam Videri
Re: Blocking off fuel sender return line w/cap [Re: ZIPPY] #79107
06/24/08 12:03 PM
06/24/08 12:03 PM
if you don't need a return line for fuel cooling purposes then a 5 cent vac cap works good. I don't know what kind of rubber they are made of but if my gas gauge makes a sudden drop I'll know that it wasn't good enough. No problems yet.
Re: Blocking off fuel sender return line w/cap [Re: RapidRobert] #79108
06/24/08 12:49 PM
06/24/08 12:49 PM
As a guy who's been around the block a few times, using a vacuum cap to plug something as dangerous as gasoline lines is playing with fire, no pun intended.
If you are sure you are never going to use the line, and once again, I'm a BIG believer in vapor return systems, solder the thing shut.
WHATEVER you use, envolving neoprene, CLAMP it. If some hot weather/ vent problem/ fuel slosh event should dislodge your vacuum cap, you could have a problem. Don't endanger your expensive classic for a twenty cent cap.
Re: Blocking off fuel sender return line w/cap #79109
06/24/08 12:53 PM
06/24/08 12:53 PM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
The cap works fine. Put a hose clamp on it if you want. My car is older so it did not have a canister. If you really want to get cool and creative, splice it into the vent line up high.
The older tanks vented into open air, pressure cannot build up unless something is plugged.
Re: Blocking off fuel sender return line w/cap [Re: Dart 340] #79110
06/24/08 05:11 PM
06/24/08 05:11 PM
Indiana
Indiana
I put a cap and clamp on. I just didn't want to throw a few gallons of $5 fuel in there to have it leak overnight because it ate through the cap.
Re: hack it with a just a fuel filter? [Re: W5Duster436] #79111
06/24/08 05:41 PM
06/24/08 05:41 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
cant you just use a 2 outlet return style fuel fitler, with a return line?
just complete the system without a charcol cansiter?
the canister only takes the vapor and changes them back to fuel and returns it via the return line. the fitler would just keep it flowing when needed.
Re: Blocking off fuel sender return line w/cap [Re: W5Duster436] #79112
06/24/08 07:12 PM
06/24/08 07:12 PM
Upper Midwest
Black_Sheep Offline
Black_Sheep  Offline
Upper Midwest
Within a year or so the cheap vacuum cap I bought from the "Help" section dissolved and leaked a huge puddle of 110 in the garage. Fuel hose with a bolt in it cured the problem. Sure it's not pretty, but neither is a burned up car or house...
'69 Plymouth GTX
See you on the street...
Re: Blocking off fuel sender return line w/cap [Re: Black_Sheep] #79113
06/24/08 10:10 PM
06/24/08 10:10 PM
I'm 60 years old, now. I've seen a few things. I've had at least one of those handy, "neat lookin'" little caps pop off a vacuum port on an early morning startup--you know the ones--when the windows are frosty, it's cold, the hood is "snowed" shut, and you're already late for work.
I sure as hell would not trust one of these on a fuel system.
Re: Blocking off fuel sender return line w/cap #79114
06/25/08 06:11 AM
06/25/08 06:11 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Re: Blocking off fuel sender return line w/cap [Re: VanishPt] #79115
06/25/08 01:12 PM
06/25/08 01:12 PM
Indiana
Indiana
I will remove it and solder it when I get a chance.
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: Blocking off fuel sender return line w/cap [Re: W5Duster436] #79116
06/25/08 01:13 PM
06/25/08 01:13 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Sounds like a good idea to me
Re: Blocking off fuel sender return line w/cap [Re: OzHemi] #79117
06/25/08 07:03 PM
06/25/08 07:03 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I agree those cheap multi-colored "vacuum caps" are made of vinyl, not even close to being fuel resistant.
Re: Blocking off fuel sender return line w/cap [Re: bigslant6fan] #79118
06/25/08 07:08 PM
06/25/08 07:08 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
Found a golf tee in mine seems to have worked.
NS1AAR
Re: Blocking off fuel sender return line w/cap [Re: ns1aar] #79119
06/25/08 07:10 PM
06/25/08 07:10 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Must be hard to fit under there with the club...
FOOOOOOOOOOOOOOUR....
