MSD IGN. AND CHALLENGER RALLYE DASH TACH #789613
08/31/10 09:46 PM
08/31/10 09:46 PM
Dennispsalm91 Offline OP
Swaped out the stock ignition for msd. Following the msd instructions, now my tach from my rallye dash doesnt work. Anyone had this problem ? Any help would be appreciated
Re: MSD IGN. AND CHALLENGER RALLYE DASH TACH [Re: Dennispsalm91] #789614
08/31/10 09:52 PM
08/31/10 09:52 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Is it a 6a?
I just installed one this weekend and used the tach output terminal on the back of the box and my tach worked fine. Potentially different technology than your stock dash tach though, but I was able to use my aftermarket (autometer) tach and also my Craftsman Tach/Dwell/Volt meter also to see RPMs.
Re: MSD IGN. AND CHALLENGER RALLYE DASH TACH [Re: Pat_Whalen] #789615
08/31/10 10:53 PM
08/31/10 10:53 PM
Yes is a 6 a box. the wire that goes to the tack neg is there. Im wondering about the plug in from stock distributor to the plug in on the wire harness, which is unpluged now has something to do with it not working
Re: MSD IGN. AND CHALLENGER RALLYE DASH TACH [Re: Dennispsalm91] #789616
08/31/10 11:13 PM
08/31/10 11:13 PM
Sydney,Australia
tex013 Online content
tex013  Online Content
Sydney,Australia
msd do a signal converter,runs inline.
i had to fit one to a 69 charger with tic toc tach
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: MSD IGN. AND CHALLENGER RALLYE DASH TACH [Re: tex013] #789617
08/31/10 11:29 PM
08/31/10 11:29 PM
IN
ahy Offline
ahy  Offline
IN
You need the signal adaptor. MSD sells several. Summit lists the different types and applications. My 70 Rally tach needed one of the basic lower priced adaptors. Wired per instructions and the tach works.
