rear suspension problem #789605
08/31/10 09:40 PM
08/31/10 09:40 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Car is a 69 Coronet R/T convert. The car has Dynamat and Dynapad installed throughout the car. The trunk has been completely boxed in with carpet and extra insulation for sound deadening. Even with heavy duty NEW rear leaf springs, the car sags. The springs are almost flat. I am sure that it is from the extra weight (estimate 500-600 pounds). What would you suggest to improve ride height and handling.
Re: rear suspension problem [Re: TrueTripleX] #789606
08/31/10 10:03 PM
08/31/10 10:03 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
load leveler shocks
air bags
heavier duty springs
I am truckless..
Re: rear suspension problem [Re: 340SHORTY] #789607
08/31/10 10:40 PM
08/31/10 10:40 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
To correct ride height, get the springs rearched or buy new ones.
To improve handling, you need a stiffer spring. Again new ones, with a higher spring rate. Or add a leaf to your old stack.
Re: rear suspension problem [Re: Magnum] #789608
09/01/10 01:57 PM
09/01/10 01:57 PM
Ball Ground GA
Ball Ground GA
As mentioned, the springs on the car are brand new HD from Mopar. not sure that rearching will help and i don't know who would have some "super HD" springs. Any and all help will be appreciated
Re: rear suspension problem [Re: TrueTripleX] #789609
09/01/10 05:12 PM
09/01/10 05:12 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
mopar springs are designed to be in a nearly flat position when installed, so they are doing exactly what they are supposed to do. The flatness of them is actually a greater benefit to handling than having a high arch.
If you want additional ride height or load capacity out of them, they would need to be custom built for that purpose. Since you already have them in, you can add a leaf to get a couple more inches of lift from them for arond $50, or you can buy a new set for another $200-250 with additional arch built in them. Best source of these would be Espo.
Re: rear suspension problem [Re: TC@HP2] #789610
09/01/10 11:47 PM
09/01/10 11:47 PM
Red Lion, PA USA
scamper340 Offline
scamper340  Offline
Red Lion, PA USA
Have you looked at adjustable front spring hangers, I'm assuming they make them for B-bodies. Or could you possibly flip the front hangers? Not versed in B-bodies, but I've heard of guys doing it on A-bodies to gain some height.
Re: rear suspension problem [Re: scamper340] #789611
09/02/10 09:05 AM
09/02/10 09:05 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I have done alot of customers cars with new mopar springs. They do seem to be lower than maybe some of the originals. Since the customers usually had larger tires than stock on the back they need more clearance so i just had them rearched 2 inches and they work perfect.
JAKES AUTOMOTIVE
Re: rear suspension problem [Re: TrueTripleX] #789612
09/02/10 12:00 PM
09/02/10 12:00 PM
Magnum Offline
Magnum  Offline
You asked 2 questions. Ride height and handling.
Rearching them WILL give you more ride height without changing the srping rate. Is that what you want?
Since you mentioned you've added 500 lbs (which sounds like alot BTW). Adding a leaf will increase the spring rate. This will improve your handling and that is a common practice when carring more load.
Rearch = ride height.
Add spring = add spring rate.
Flipping the front hanger is about 1/2" higher.
