"N" safety switch ? #789343
08/31/10 06:07 PM
08/31/10 06:07 PM
Branson, Mo.
joedust451 Offline OP
super gas
super gas
Branson, Mo.
Maybe someone can help, I installed a floor shifter a while back, not too long ago i took the selector arm off the column, of coarse if it comes down any it won't crank, but last time out, i would push it up & still nothing, i moved the floor shifter to "P" & "N" & still nothing, i had to jump the starter relay, I thought there was a way to install a jumper wire to by-pass the safety switch, how can this be done, or is there something i can disconnect on the selector arm (column) to eliminate this problem. I thought it might be the safety switch, but its working fine now, just don't want anymore problems or have it happen again, it seems to act up at the "wrong" time .
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: "N" safety switch ? [Re: joedust451] #789344
08/31/10 07:47 PM
08/31/10 07:47 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you have the 3 wire switch on trans, then the original column shifter is not involved in the starting. What year?
Re: "N" safety switch ? [Re: joedust451] #789345
08/31/10 08:36 PM
08/31/10 08:36 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
What kind of floor shift did you install?
As the other reply posted, you should have the 3 pin neutral safety switch in the trans.
It's probably a case of the shifter being out of adjustment.
To verify that, hold your foot on the brakes, twist the key to start/crank and move the shifter back through the gears.
It will only start when the trans is in park or neutral.
Where the shifter says it is may be a whole different thing if the adjustment is off.
It could also be that the wire is broken or the plug came off at the trans.
Do your back-up light work when in reverse?
They're run through the same trans switch (the other two wires).
Re: "N" safety switch ? [Re: SNK-EYZ] #789346
08/31/10 09:56 PM
08/31/10 09:56 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Its a 71 Swinger, it does have the 3 wires, it doesn't do it all the time, but IF i lower the original column where the shifter arm was (or it falls on its own) it won't start in any gear, if i shuv it back in place it'll turn over like it should (in "N" & "P"), but "sometimes" it acts up & won't turn-over, so i'm thinking its in the column, there must be a wire or something that column.
I'll double check the position of the arm on the trans with my floor shifter & make sure its adj.
Re: "N" safety switch ? [Re: buildanother] #789347
08/31/10 09:59 PM
08/31/10 09:59 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
How could it NOT be involved, it has to be
Re: "N" safety switch ? [Re: joedust451] #789348
08/31/10 10:04 PM
08/31/10 10:04 PM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
I am having similar problems with mine. I have a 73, but it looks like I am going to have to re-wire the center wire on the switch directly to the starter relay.
Re: "N" safety switch ? [Re: joedust451] #789349
08/31/10 10:09 PM
08/31/10 10:09 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
It's not, all the wiring goes thru the neutral safety switch. To bypass it ground the terminal on the starter relay and it's out of the circuit. Got to be careful as the car will start in gear.
Re: "N" safety switch ? [Re: Challenger 1] #789350
08/31/10 10:16 PM
08/31/10 10:16 PM
CONNECTICUT
RoyceFlo73 Offline
RoyceFlo73  Offline
CONNECTICUT
What if you don't want to bypass it and you don't want it to be able to start in gear? it didn't do that from the factory did it?
Re: "N" safety switch ? [Re: RoyceFlo73] #789351
08/31/10 10:21 PM
08/31/10 10:21 PM
Cincinnati, Ohio
Cincinnati, Ohio
I am only recommending to bypass it temporally to see if it is the problem. If it is then the shifter linkage needs to be adjusted.
Re: "N" safety switch ? [Re: RoyceFlo73] #789352
08/31/10 10:27 PM
08/31/10 10:27 PM
A Red State
A Red State
The neutral safety can be bypassed by pulling the brown wire off the starter relay and running a jumper wire from that stud on the relay to ground.
It's grounded through the tranny when it's working properly.
I would not recommend doing it as there's a reason that it called a neutral safety switch.
It prevents the car from being started in gear and running over anyone.
The neutral safety is required to work to pass the tech inspection at the track.
As far as moving anything on the column, is there any linkage still attaching it to the trans linkage?
Re: "N" safety switch ? [Re: SNK-EYZ] #789353
08/31/10 10:42 PM
08/31/10 10:42 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Grounding it like that is like putting a standard(manual transmission) starter relay on it. Like said above it was suggested to see if that's the problem. Cause it might be in the relay itself....but most of the time if I'm not mistaken it's the switch in the trans. Which you can go get a new one at Napa here is this part # ECH NS6562.
Moparlee
Re: "N" safety switch ? [Re: SNK-EYZ] #789354
08/31/10 10:42 PM
08/31/10 10:42 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
No, all the linkage is gone, ok now i see it would have nothing to do with it anymore , i'm a dumbazz . The only conclusion i can come to is its either the adj. is off, the switch is going bad (this is most likly the problem), or its getting a weak connection, OR could it be in the starter relay , i have noticed its acted up alot more sence i installed a new cable for the shifter.
Re: "N" safety switch ? [Re: Robbins] #789355
08/31/10 10:45 PM
08/31/10 10:45 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Thanks for the part # Robins, i might as well get a new relay too.
Re: "N" safety switch ? [Re: joedust451] #789356
08/31/10 11:17 PM
08/31/10 11:17 PM
A Red State
A Red State
Here's a pic of the switch, it screws into the trans.
It's spring loaded in the trans (white plastic end), sometimes the spring goes bad and it can't make contact to ground.
Re: "N" safety switch ? [Re: joedust451] #789357
08/31/10 11:24 PM
08/31/10 11:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I would look at the adjustment first , if it was working before then it's the adjustment of the new cable .
Re: "N" safety switch ? [Re: JohnRR] #789358
08/31/10 11:31 PM
08/31/10 11:31 PM
Branson, Mo.
super gas
super gas
Branson, Mo.
Even before it would act up on acassion, but not this bad, i know those safety switches are sensitive as to there possitioning.
Re: "N" safety switch ? [Re: joedust451] #789359
08/31/10 11:40 PM
08/31/10 11:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Also check the bulkhead wiring connections then. If the switch is position sensitive then the shifter is either out of adjustment or it's a bad switch .
Re: "N" safety switch ? [Re: JohnRR] #789360
08/31/10 11:51 PM
08/31/10 11:51 PM
A Red State
A Red State
The brown (center wire on the switch) goes from the switch straight to the starter relay. It may have a connector somewhere in between, some cars don't.
It doesn't go through the firewall bulkhead connector, it stays in the engine compartment from 1969 on.
