Water pouring in from fresh air vent 71 Duster #78866
06/23/08 07:37 PM
06/23/08 07:37 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I've got a big leak, the drivers side fresh air vent down by my feet leaks badly. It just pours when the vent door is open I can look up the vent and see daylight. Is there a plugged up drainage channel somewhere?
Re: Water pouring in from fresh air vent 71 Duster [Re: dmerc] #78867
06/23/08 08:38 PM
06/23/08 08:38 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The cowl end vents are probably plugged. Small 1 1/2 inch wedge shaped drains on each side of upper cowl. Never tried to clear them with fenders in place, but there has to be a way.
Re: Water pouring in from fresh air vent 71 Duster [Re: buildanother] #78868
06/23/08 08:50 PM
06/23/08 08:50 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
There are inspection covers in both fenders
that can be unsrewed to access that area.
Other than that it might take removing the
fresh air vent to gain access.
Phil Saran
CA Duster 383
Fullerton, CA
Re: Water pouring in from fresh air vent 71 Duster [Re: Phil Saran] #78869
06/23/08 09:18 PM
06/23/08 09:18 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Thanks guys I need to get this problem solved before the new carpet goes in.
Re: Water pouring in from fresh air vent 71 Duster [Re: dmerc] #78870
06/23/08 09:39 PM
06/23/08 09:39 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
blow air up the drain hole. maybe its simply blocked?
Re: Water pouring in from fresh air vent 71 Duster [Re: mark7171] #78871
06/25/08 10:44 PM
06/25/08 10:44 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
If the drain holes do not solve you problems. Check the dam. It circles the entrance to vent. They are sometimes corroded or the leaves and dirt are built up as high as the dam.
Re: Water pouring in from fresh air vent 71 Duster [Re: dmerc] #78872
06/25/08 10:56 PM
06/25/08 10:56 PM
Arkansas
340727dart Offline
340727dart  Offline
Arkansas
I just went through this with my '71 Dart. The cowl drains on both sides were plugged with leaves and junk. The passenger side was plugged with a hornet's nest.
I ended up drilling a 1/2" hole in the firewall and used high pressure water to blow the nest out of there. I plugged the hole with a metal plug.
Yes, water poured into the passenger compartment until I got that nest out of there.
Fortunately, my shop vac got all the water out.
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Water pouring in from fresh air vent 71 Duster [Re: 340727dart] #78873
06/26/08 10:11 PM
06/26/08 10:11 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I drilled a hole in the cowl in my Duster in high school also. short of that, a coat hanger and compressed air or high pressure water. With no screens in the cowl vent, it doesn't take long at all parked under a tree before all kinds of junk gets trapped down there and starts turning back into dirt. I've had good success with a coat hanger stuck up into the drains fishing around (with the fenders on) while a garden hose runs down into the cowl vent, it will take a while, but you'll get alot out. If you take the fresh air vent off, or otherwise stick you hand up there from the bottom... beware of sharp edges, they never intended hands to be in there!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Water pouring in from fresh air vent 71 Duster [Re: GO_Fish] #78874
06/27/08 09:52 AM
06/27/08 09:52 AM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
Hopefully the ring around the top of the cowl vent hole isn't rusted out. It's a pretty common issue on cars that have sat under trees.
Re: Water pouring in from fresh air vent 71 Duster [Re: Paul] #78875
06/27/08 02:40 PM
06/27/08 02:40 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Thanks for the tips fellas Got her unplugged and also found a couple leaks behind the kick panels where all the sheetmetal comes together.
