Re: E Body Manual
[Re: Zapp]
#787834
08/30/10 10:38 AM
08/30/10 10:38 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Im currently rebuilding my Challenger taking lots of pics as I pulled it apart but I thought I should get a Manual in case I forget the order things go together. Ive got the mechanical side sorted but what manual is best showing window regulators, grill assembly and other body related stuff. Its a 1970 if that makes a difference.
The factory service manual is worth its weight in gold. You can find an occasional original on Ebay. Those are the best. There are PDF versions available on CD ROM that are pretty good. I find the pictures do not print as well as the original factory manual did. I have an original factory manual for a 1971 Cuda that I use a lot because the pictures and diagrams are clearer but check with my CD ROM version that is specifically for the 73 to make sure there were no changes between the model years. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
Re: E Body Manual
[Re: Alaskan_TA]
#787836
08/30/10 08:40 PM
08/30/10 08:40 PM
Posts: 396 BC
70RT27N
BC
