318 poly rocker shaft removal? #787498
08/29/10 10:50 PM
08/29/10 10:50 PM
California
P
polkat Offline OP
mopar addict
polkat  Offline OP
mopar addict
P
California
About to pull the heads from my 318 poly (in a 1964 Fury). Never pulled poly heads before, and I am wondering if anything special is involved in pulling the rocker shafts?
Also, how does one get that dang lower exhaust manifold bolt out thats just above the steering box??
Thanks!
Re: 318 poly rocker shaft removal? [Re: polkat] #787499
08/30/10 09:57 AM
08/30/10 09:57 AM
Andrewh Offline
Andrewh  Offline
they come off when you unbolt a few head bolts.
that is what holds the rocker shaft down.
Don't remember having that problem with the exhaust. But I was working on a 66 at the time.
