Short oil filter for 70 HP 340 manifolds??? #78711
06/23/08 08:43 AM
06/23/08 08:43 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Is there a short oil filter that will fit? I have the early style 340 manifolds with a TTI 2 1/2 exhaust system. I currently have the 90 degree adapter but would like to simplify if possible.
Re: Short oil filter for 70 HP 340 manifolds??? [Re: dmerc] #78712
06/23/08 09:06 AM
06/23/08 09:06 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I use the small 3614 (fram number) filter on every thing and there are a number of us that have used this for years rather than have a bunch of different filters around. Use clean oil and keep it changed regularly 2/3000miles and you will have no problem with it. There is also one that is slightly bigger but I can't remember the number off hand.
Re: Short oil filter for 70 HP 340 manifolds??? [Re: MoparforLife] #78713
06/23/08 10:52 AM
06/23/08 10:52 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
yes the #is ph43 i think. but will the small 2.2 (3614) fit under 340 manifolds. i was just looking yesterday and it doesn't look like it would fit. i would love to get rid of that leaky 90 adapter.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Short oil filter for 70 HP 340 manifolds??? [Re: MoparforLife] #78714
06/23/08 11:30 AM
06/23/08 11:30 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
I wouldn't use the 3614 size filter that filter only holds a few ounces of oil and is likely bypassing much of the time. Every vehicle that I have ever had that used that size filter the first oil change I wnet to the largest filter that will fit.
A PH43 size (I use Motorcraft FL300) is the next step down from the PH8A size filter and it fits just fine on both my 360 with headers and my Dakota. There is another one that is still the larger diameter but is even shorter than the PH43 size filter it's a PH16 and is what they put on most vehicles when you have the oil changed at the dealer.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: Short oil filter for 70 HP 340 manifolds??? [Re: dgc333] #78715
06/23/08 11:53 AM
06/23/08 11:53 AM
FWIW, I have the right-angle setup on a 340 and a 360; only problem I've ever had is that most rebuild kits don't give you all the gaskets you need for the adaptor, but they are available separately. Otherwise, I've never had a problem, my 65 Barracuda's had the right-angle setup since it was new, I know I'm an old poot, but it seems normal to me, and I'd rather run the bigger filter.
Re: Short oil filter for 70 HP 340 manifolds??? #78716
06/23/08 05:01 PM
06/23/08 05:01 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
If it aint broke, why fix it? Looks like I'll just use it as is. If it leaks then I'll try the shorty filter.
