Re: Trunk floor pan and extensions install question..
[Re: scratchnfotraction]
#786676
08/29/10 10:36 PM
08/29/10 10:36 PM
Posts: 15,487 Florida
scratchnfotraction
cut a long bed floor down and put it in a short box little off each end and the tub cut in hand rubbed with filler on the end cuts very interested in how you would do a car now..what a learning curve body work can be
#786677
08/29/10 10:43 PM
08/29/10 10:43 PM
scratchnfotraction
replaced the bulk head also i will stop bragging now good luck with you trunk extintions are you gonna post pics of a step by step project? i would be interested in seeing it
[Re: VIPERDUST]
#786678
08/30/10 07:13 PM
08/30/10 07:13 PM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
I would have the 1/4's on to locate the trunk ext. The aftermarket replacement parts are close, but the are never right. You have to cut, bend, twist, hammer.....etc. to make all these parts to work together.
