Trunk floor pan and extensions install question.. #786671
08/29/10 12:46 AM
08/29/10 12:46 AM
missouri, USA
moparmojo Offline OP
missouri, USA
Doing my first resto and have a question. When installing a trunk floor pan and extensions is it necessary to have the quarters on and located? Preferably I would want them on to help properly locate the floor pan, but I was wondering if it could be done without them. Im trying to decide if I need to buy the quarters now too. Money is tight like always and that is why I am asking. Any install advice?
Re: Trunk floor pan and extensions install question.. [Re: moparmojo] #786672
08/29/10 01:27 AM
08/29/10 01:27 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Hey . . . I to am going to be doing my own metal work in the near future (I hope) . . . I have bought the complete quarters, outer wheel house, trunk floor (one piece) and trunk floor extensions. . . .
My idea was going to be to take one side off the car (quarter panel) and then do the trunk floor, as I would be able to slide it in from the one side. I think it will be easier this way . . . maybe I am wrong ???
Cheers
Mark
Re: Trunk floor pan and extensions install question.. [Re: moparmojo] #786673
08/29/10 09:51 PM
08/29/10 09:51 PM
kalamazoo, MI.
VIPERDUST Offline
VIPERDUST  Offline
kalamazoo, MI.
I would have the 1/4's on to locate the trunk ext. The aftermarket replacement parts are close, but the are never right. You have to cut, bend, twist, hammer.....etc. to make all these parts to work together.
Re: Trunk floor pan and extensions install question.. [Re: VIPERDUST] #786674
08/29/10 10:28 PM
08/29/10 10:28 PM
scratchnfotraction Offline
most likely wont help but,,
i just did my first floor in a truck bed
Re: Trunk floor pan and extensions install question.. [Re: scratchnfotraction] #786675
08/29/10 10:29 PM
08/29/10 10:29 PM
and tubed it
Re: Trunk floor pan and extensions install question.. [Re: scratchnfotraction] #786676
08/29/10 10:36 PM
08/29/10 10:36 PM
cut a long bed floor down and put it in a short box
little off each end and the tub cut in
hand rubbed with filler on the end cuts
very interested in how you would do a car now..what a learning curve body work can be
Re: Trunk floor pan and extensions install question.. [Re: scratchnfotraction] #786677
08/29/10 10:43 PM
08/29/10 10:43 PM
replaced the bulk head also
i will stop bragging now
good luck with you trunk extintions
are you gonna post pics of a step by step project?
i would be interested in seeing it
Re: Trunk floor pan and extensions install question.. [Re: VIPERDUST] #786678
08/30/10 07:13 PM
08/30/10 07:13 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
