Re: transmission question!
[Re: BigTerry]
#786453
08/29/10 02:21 AM
08/29/10 02:21 AM
Posts: 2,005 s. e. pa.
calrobb2000
s. e. pa.
hi what vehicle ? scan for codes ? bad tps maby ?
[Re: BigTerry]
#786457
08/29/10 03:53 PM
08/29/10 03:53 PM
Posts: 25,960 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some of the larger chain auto supplies will read the codes for you for free.
Re: transmission question! getting desperate...
[Re: moparsquid]
#786464
09/02/10 09:40 AM
09/02/10 09:40 AM
Posts: 75,089 A Banana Republic near you.
JohnRR
what controls the line pressure?
46RE has an electronic governor but the line pressure is controlled by a regulator valve just like a 727.
Terry , you need to take it to a shop , it's very hard to try to diagnose your problem as evidenced by the silence of those that are very knowledgeable in these transmissions.
[Re: BigTerry]
#786467
09/03/10 01:32 AM
09/03/10 01:32 AM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Governor pressure transducer or sensor problem wouldn't surprise me...along with a possible bad seal in the rear clutch piston. If it's a sensor problem, there should be a P code when scanned. Be careful who you "trust" to check this out.
[Re: superwrench]
#786468
09/03/10 10:55 AM
09/03/10 10:55 AM
Posts: 1,481 Outside
thedriver
Outside
trans modules, pressure reducers, governers ...man, i'd just go buy a clutch.
1973 challenger Dana. 4 speed. Low deck.
[Re: thedriver]
#786469
09/03/10 11:47 PM
09/03/10 11:47 PM
Posts: 3,688 Alexandria,La.
BigTerry
Alexandria,La.
