Intrepid starting hard when hot
#785941
08/27/10 09:20 PM
08/27/10 09:20 PM
Posts: 546 Gilman, IA
sabbfan
Gilman, IA
I have a '99 Intrepid with the 3.2, 105k miles. It starts just fine when it has been sitting a while, but if i go to start it shortly after shutting it off it cranks over for a while and idles rough at first, then smooths out. It runs excellent other than this. Any ideas?
2012 Ram 2500 Crew Cab 4x4 5.7 Hemi 2011 Dodge Durango 3.6L 2009 Dodge Caliber 1.8L 5 speed 1970 Super Bee-someday!
Re: Intrepid starting hard when hot
[Re: sabbfan]
#785942
08/27/10 09:28 PM
08/27/10 09:28 PM
Posts: 905 SD
zrxkawboy
SD
I would start by checking fuel pressure.
It's Swifty! Swifty, you toad sucker!
[Re: zrxkawboy]
#785943
08/27/10 09:36 PM
08/27/10 09:36 PM
Posts: 1,377 Ohio
Todd
Ohio
Put a pressure gauge on it and see if it bleeds off without the engine running.
[Re: Todd]
#785944
08/27/10 10:01 PM
08/27/10 10:01 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
when it does bleed off, what does that indicate is in trouble?
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#785945
08/27/10 10:30 PM
08/27/10 10:30 PM
Posts: 905 SD
zrxkawboy
SD
It could bleed off fuel pressure, usually via a leaking: injector, regulator, or fuel pump. However, if it did this, I'd think it would start hard cold, too. It's just that fuel pressure is a good place to start.
[Re: zrxkawboy]
#785946
08/27/10 10:32 PM
08/27/10 10:32 PM
Posts: 905 SD
zrxkawboy
SD
I suppose that if it did bleed off fuel somewhere, resulting in lower pressure, then it could vapor lock when hot. When it cooled down, though, it might be OK again.
