Fired up motor...question on red headers... #783750
08/25/10 10:19 AM
08/25/10 10:19 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I fired up my motor for the first time last night after the rebuild. New pistons, rings, rods, bearings, main caps, etc..
I borrowed a carb (950hp) for the break in before the FAST kit.
I know motors tend to run a little hot on initial run because of everything being tight, and the collector ends of the headers (these are shorty) were red and flames were shooting out while it was running at about 1600-1700 rpms.
I am assuming this is because the carb is dead fat and the excess fuel is burning off? The plugs were very black too.
I have never run a motor with shorties, much less open headers, so I don't know if the "flames" part is normal? Water temperature wise, everything was normal.
Re: Fired up motor...question on red headers... [Re: TheOtherDodge] #783751
08/25/10 10:25 AM
08/25/10 10:25 AM
an8sec70cuda Offline
Late timing probably.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fired up motor...question on red headers... [Re: an8sec70cuda] #783752
08/25/10 10:39 AM
08/25/10 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep... its firing late and burning in the tubes
Re: Fired up motor...question on red headers... [Re: MR_P_BODY] #783753
08/25/10 10:50 AM
08/25/10 10:50 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I'm also gonna jump in with it needs more timing! if your numbers are OK check and see if your damper/pointer are correct.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Fired up motor...question on red headers... [Re: bigtimeauto] #783754
08/25/10 11:03 AM
08/25/10 11:03 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Almost always not enough ignition timing as previous stated, especially harsh under no load... Crank it up into the mid 30's should cool right off.
Re: Fired up motor...question on red headers... [Re: bigtimeauto] #783755
08/25/10 11:03 AM
08/25/10 11:03 AM
Houston, Texas
Houston, Texas
You guys are good! I think my timing is a little late...I just set it by "eye method" by lining up the balancer mark, looking at where the rotor is pointing to on the cap... I didnt want to put too much advance in at first...
I will check it with a gun this eve.
Re: Fired up motor...question on red headers... [Re: TheOtherDodge] #783756
08/26/10 12:30 PM
08/26/10 12:30 PM
Houston, Texas
Houston, Texas
Ya, you guys are right. I only had about 6 degrees of total advance. I changed it to 30 at 1800 rpms and no more red!
