Fired up motor...question on red headers...
#783750
08/25/10 10:19 AM
08/25/10 10:19 AM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
I fired up my motor for the first time last night after the rebuild. New pistons, rings, rods, bearings, main caps, etc.. I borrowed a carb (950hp) for the break in before the FAST kit. I know motors tend to run a little hot on initial run because of everything being tight, and the collector ends of the headers (these are shorty) were red and flames were shooting out while it was running at about 1600-1700 rpms. I am assuming this is because the carb is dead fat and the excess fuel is burning off? The plugs were very black too. I have never run a motor with shorties, much less open headers, so I don't know if the "flames" part is normal? Water temperature wise, everything was normal.
Re: Fired up motor...question on red headers...
[Re: TheOtherDodge]
#783751
08/25/10 10:25 AM
08/25/10 10:25 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#783752
08/25/10 10:39 AM
08/25/10 10:39 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Late timing probably.
Yep... its firing late and burning in the tubes
