what plugs to use in 340 stroker??
#783608
08/25/10 01:05 AM
08/25/10 01:05 AM
Posts: 1,365 elmira ny
hp340nos
elmira ny
what are you guys running for spark plugs in your 340 strokers?i have a pump gas 340 4" 418 cid, 9.7 comp.solid roller.246dur@.050,.580 lift,x-heads ported/polished.msd6al with blaster2 coil.looking for what brand,heat range and gap.thanks mike
Re: what plugs to use in 340 stroker??
[Re: hp340nos]
#783610
08/25/10 02:53 PM
08/25/10 02:53 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
Which heads, iron or aluminum?
[Re: hp340nos]
#783612
08/25/10 05:43 PM
08/25/10 05:43 PM
Cab_Burge
I agree with Phil on this one Autolite 65 or 64 I lke to run my motors leaner with a colder plug than most do Not to hijack but Phil, do you run the same plug when racing and using NOS?
[Re: hp340nos]
#783616
08/26/10 11:35 AM
08/26/10 11:35 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
RIP Monte Smith
