what plugs to use in 340 stroker?? #783608
08/25/10 01:05 AM
08/25/10 01:05 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
what are you guys running for spark plugs in your 340 strokers?i have a pump gas 340 4" 418 cid, 9.7 comp.solid roller.246dur@.050,.580 lift,x-heads ported/polished.msd6al with blaster2 coil.looking for what brand,heat range and gap.thanks mike
Re: what plugs to use in 340 stroker?? [Re: hp340nos] #783609
08/25/10 09:30 AM
08/25/10 09:30 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
autolite 65
Re: what plugs to use in 340 stroker?? [Re: hp340nos] #783610
08/25/10 02:53 PM
08/25/10 02:53 PM
Which heads, iron or aluminum?
Re: what plugs to use in 340 stroker?? [Re: Cab_Burge] #783611
08/25/10 04:45 PM
08/25/10 04:45 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
cast iron.
Re: what plugs to use in 340 stroker?? [Re: hp340nos] #783612
08/25/10 05:43 PM
08/25/10 05:43 PM
I agree with Phil on this one Autolite 65 or 64 I lke to run my motors leaner with a colder plug than most do Not to hijack but Phil, do you run the same plug when racing and using NOS?
Re: what spark plugs to use in 340 stroker?? [Re: Cab_Burge] #783613
08/25/10 06:51 PM
08/25/10 06:51 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
what about the 5/8 socket plug say a autolite 3923 or a 3924??thanks mike
Re: what spark plugs to use in 340 stroker?? [Re: hp340nos] #783614
08/25/10 11:47 PM
08/25/10 11:47 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i was told that its the same plug as the 64/65 just use the smaller socket i tried the 65/64/3924 and seen no diff. but was tuneing as well
Re: what spark plugs to use in 340 stroker?? [Re: hp340nos] #783615
08/26/10 01:34 AM
08/26/10 01:34 AM
Those will probally work also, I'm not familar with the heat range on either one of those plugs so I have used the autolite 3911 and 3910 in my BB stroker with Edlebrock aluminum heads as well as the Champion RC12YC and RC9YC with good results I think the stock 340 plugs where RN9Y or N9Y before Champion changed the center ground electrode to copper hence the RN9YC and N9YC now. The RC9YC is the 5/8 plug with the same thread depth, size and heat range as the RN9YC for the iron SB heads
Re: what plugs to use in 340 stroker?? [Re: hp340nos] #783616
08/26/10 11:35 AM
08/26/10 11:35 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
AR 53 or the AR3923
RIP Monte Smith
Re: what plugs to use in 340 stroker?? [Re: CompWedgeEngines] #783617
08/26/10 06:14 PM
08/26/10 06:14 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
thanks guys i will get a set of ar3923 then,thanks mike
