SB 90 oil filter adapter ?s #78299
06/22/08 11:46 AM
06/22/08 11:46 AM
Kansas
racincuda Offline OP
Kansas
With the not so new invention of the miniature oil filters (2.2L style) I was wondering if ther is really any reason to continue using the 90 degree filter adapter
Mine has sprung a leak at th block so was thinking of leaving it off and using the smaller filter to clear headers. Actually I think th std filter may actually fit without this adapter but would be really close to headers.
Soo are any of you still using the 90 degree adapter ?
And why ?
At this point it's starting to look like one more potential failure/ what th HeL it just failed
Re: SB 90 oil filter adapter ?s [Re: racincuda] #78300
06/22/08 12:04 PM
06/22/08 12:04 PM
would it be easier to order another MP gasket set for cheap,clean everything up good & have fresh gaskets.
Re: SB 90 oil filter adapter ?s [Re: RapidRobert] #78301
06/22/08 12:10 PM
06/22/08 12:10 PM
Kansas
Kansas
No, the labor is the same either way so why does anybody use these adapters when a small filter will clear everything
I already hav parts to go either way
Re: SB 90 oil filter adapter ?s [Re: racincuda] #78302
06/22/08 12:25 PM
06/22/08 12:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Since you can go both ways..i guess the decision is yours....
Tony
70 AARCuda Vitamin C
Re: SB 90 oil filter adapter ?s [Re: racincuda] #78303
06/22/08 12:50 PM
06/22/08 12:50 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
I went to went back to the stock filter plate (modded w/ 4 additional holes) and a K&N shorty style filter.No more oil dripping on the headers from the 90* adapter ,D.
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: SB 90 oil filter adapter ?s [Re: bigD] #78304
06/22/08 12:58 PM
06/22/08 12:58 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Never had a problem with the adapter, just need to use the proper gaskets and make sure the fastener is tight.
I like the biggest filter I can use; the tiny ones seem to me run in bypass too much if you have 50-80 PSI oil pressure.
Re: SB 90 oil filter adapter ?s [Re: racincuda] #78305
06/22/08 02:30 PM
06/22/08 02:30 PM
Good point but I agree with topside,a smaller filter has way less filtering area & bypasses to much.
Re: SB 90 oil filter adapter ?s [Re: RapidRobert] #78306
06/22/08 04:41 PM
06/22/08 04:41 PM
Kansas
Kansas
At this point I tend to agree with bigD
however I dont want to bypass a lot of oil either how do U kno it's getting bypassed
Re: SB 90 oil filter adapter ?s [Re: racincuda] #78307
06/22/08 05:48 PM
06/22/08 05:48 PM
greenfield, ind.
P
PLMCRZY Offline
PLMCRZY  Offline
P
greenfield, ind.
unless you have a clearance issue,what big d says is right on, did the same thing myself. dennis
Re: SB 90 oil filter adapter ?s [Re: PLMCRZY] #78308
06/22/08 06:02 PM
06/22/08 06:02 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i have the stock 340hp exhaust manifolds on my cuda. thats why i have to use the 90 adapter. and yes it leaks with new gaskets. on my duster i have headers and either filter will fit and it doesn't leak.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: SB 90 oil filter adapter ?s [Re: 65cuda] #78309
06/22/08 10:36 PM
06/22/08 10:36 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I have had a lot of problems with those stupid things leaking and most aplications don't really need them. The short fat oil filters are fine. Also if you have an iron adapter that is a nice little chunk of weight to ditch
Re: SB 90 oil filter adapter ?s [Re: HotRodDave] #78310
06/22/08 11:20 PM
06/22/08 11:20 PM
Tempe, AZ
loco340cuda Offline
loco340cuda  Offline
Tempe, AZ
What brand/part number are the short filters? On top of getting oil on the headers every time I change the oil I have a small leak on my adapter and I would really like to ditch it.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: SB 90 oil filter adapter ?s [Re: loco340cuda] #78311
06/22/08 11:28 PM
06/22/08 11:28 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
same as all the mopar SB take ph43 i think. and drill extra holes or enlarge the holes in the plate.
Re: SB 90 oil filter adapter ?s [Re: 65cuda] #78312
06/22/08 11:54 PM
06/22/08 11:54 PM
the ph43 is the shorter of the (2) std mopar filters. I think ph8A is the long one but are you inquiring about the one that is even way shorter than the ph43? I've seen it but I cant find the # for it.
Re: SB 90 oil filter adapter ?s [Re: RapidRobert] #78313
06/23/08 12:00 AM
06/23/08 12:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
shorter than ph43 is the ph16...
Tony
Re: SB 90 oil filter adapter ?s [Re: RapidRobert] #78314
06/23/08 12:03 AM
06/23/08 12:03 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
yes the smallest one thats the one for a 2.2 mopar it has a 4 digit # like ph3614.
Re: SB 90 oil filter adapter ?s [Re: 65cuda] #78315
06/23/08 01:50 PM
06/23/08 01:50 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The Fram PH3614 is for a neon but will seal and filter the oil for almost any mopar. It is a very small filter. For a long skinney filter the PH 3600 will fit, look up a 95 ford taurus 3.0 to get this one. Look up a filter for a 97 Ram with a 318 and you will get a PH16 if you get a Fram but they are horendus filters though, get any other brand you want just cross referance them to those numbers/vehicles.
Re: SB 90 oil filter adapter ?s [Re: HotRodDave] #78316
06/23/08 11:04 PM
06/23/08 11:04 PM
Waterloo Iowa
8
80mirada Offline
80mirada  Offline
Waterloo Iowa
ph3614 is just to damn small for a performance engine. Look up a turbo GLH like a 86 I think, there is a short fat filter for them. We used to put ph43's on 2.2, to help with oil starvation to the turbo.
