SB 90 oil filter adapter ?s
#78299
06/22/08 11:46 AM
06/22/08 11:46 AM
Posts: 650 Kansas
racincuda
Kansas
With the not so new invention of the miniature oil filters (2.2L style) I was wondering if ther is really any reason to continue using the 90 degree filter adapter ![](/ubbthreads/images/graemlins/confused.gif) Mine has sprung a leak at th block so was thinking of leaving it off and using the smaller filter to clear headers. Actually I think th std filter may actually fit without this adapter but would be really close to headers. Soo are any of you still using the 90 degree adapter ? And why ? At this point it's starting to look like one more potential failure/ what th HeL it just failed ![](/ubbthreads/images/graemlins/maad.gif)
Re: SB 90 oil filter adapter ?s
[Re: racincuda]
#78300
06/22/08 12:04 PM
06/22/08 12:04 PM
RapidRobert
would it be easier to order another MP gasket set for cheap,clean everything up good & have fresh gaskets.
[Re: PLMCRZY]
#78308
06/22/08 06:02 PM
06/22/08 06:02 PM
Posts: 515 Dayton, Ohio
65cuda
mopar addict
mopar addict
Dayton, Ohio
i have the stock 340hp exhaust manifolds on my cuda. thats why i have to use the 90 adapter. and yes it leaks with new gaskets. on my duster i have headers and either filter will fit and it doesn't leak.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
[Re: HotRodDave]
#78310
06/22/08 11:20 PM
06/22/08 11:20 PM
Posts: 755 Tempe, AZ
loco340cuda
Tempe, AZ
What brand/part number are the short filters? On top of getting oil on the headers every time I change the oil I have a small leak on my adapter and I would really like to ditch it.
70 Cuda 340 4 speed - now stroked to 416ci (SOLD) 2017 Mustang Shelby GT350
[Re: loco340cuda]
#78311
06/22/08 11:28 PM
06/22/08 11:28 PM
65cuda
mopar addict
mopar addict
Dayton, Ohio
same as all the mopar SB take ph43 i think. and drill extra holes or enlarge the holes in the plate.
[Re: 65cuda]
#78312
06/22/08 11:54 PM
06/22/08 11:54 PM
RapidRobert
the ph43 is the shorter of the (2) std mopar filters. I think ph8A is the long one but are you inquiring about the one that is even way shorter than the ph43? I've seen it but I cant find the # for it.
[Re: RapidRobert]
#78313
06/23/08 12:00 AM
06/23/08 12:00 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
shorter than ph43 is the ph16...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: RapidRobert]
#78314
06/23/08 12:03 AM
06/23/08 12:03 AM
65cuda
mopar addict
mopar addict
Dayton, Ohio
yes the smallest one thats the one for a 2.2 mopar it has a 4 digit # like ph3614.
