? Best way to Intsall Window Stainless steel trim ? #781341
08/23/10 02:05 PM
08/23/10 02:05 PM
Canada
7t8warlock Offline OP
Canada
Hi I'm looking for info on how to install the stainless steel trim around the front & rear Windows . I have all the right clips & rubbers . Should i install the clips with screws first , then install the rubber & glass. Or drill the holes for the clips after the window is in place ??????????????
Re: ? Best way to Intsall Window Stainless steel trim ? [Re: 7t8warlock] #781342
08/23/10 08:00 PM
08/23/10 08:00 PM
Arizona
69rrgrabber Offline
69rrgrabber  Offline
Arizona
I'm doing this on my 69 Charger right now. If you have already cleaned out the window channels and painted them, then add the clips and screws. Next install the seals and glass with care. If you had to add a new roof skin like me, then drill any holes you may need before you install the glass.
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: ? Best way to Intsall Window Stainless steel trim ? [Re: 69rrgrabber] #781343
06/27/11 01:34 PM
06/27/11 01:34 PM
Canada
Canada
I need to know from someone , what color clip goes above the front window drip rail & what color for the sides & bottom . The clips are green & redish brown . I don't have any books or a good glass guy to tell me . Stainless trim came off a 76 adventuer se .
Re: ? Best way to Intsall Window Stainless steel trim ? [Re: 7t8warlock] #781344
06/28/11 09:54 AM
06/28/11 09:54 AM
Canada
Canada
any pics guys
