1972 challenger wiper motor #781318
08/23/10 01:53 PM
08/23/10 01:53 PM
MD
HEMI472 Online content OP
HEMI472  Online Content OP
MD
will a 1970-1971 challenger 3 speed wiper motor work on a 1972 challenger???? thanks ed
Re: 1972 challenger wiper motor [Re: HEMI472] #781319
08/23/10 02:13 PM
08/23/10 02:13 PM
GA
Boosted Offline
Boosted  Offline
GA
They must be diffrent ... i looked them up online and can find a reman motor for a 72 3 spd or 2 spd but nothing for a 70-71...
3spd was 63 and 2spd weas 48 at oriely for a 72...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: 1972 challenger wiper motor [Re: Boosted] #781320
08/23/10 03:12 PM
08/23/10 03:12 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The motors are different in appearance but I think they will work. Jules will know for sure. Hopefully he will see this.
Re: 1972 challenger wiper motor [Re: burdar] #781321
08/23/10 03:19 PM
08/23/10 03:19 PM
MD
MD
my car is a 72 but the wiper motor on it looks like the 70-71 style not the 72-74 style with the black plastic cover. could my car be a early 72 and have a 71 wiper???? thanks ed
Re: 1972 challenger wiper motor [Re: HEMI472] #781322
08/23/10 03:26 PM
08/23/10 03:26 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
What is the cars SPD?
Re: 1972 challenger wiper motor [Re: burdar] #781323
08/23/10 05:05 PM
08/23/10 05:05 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
The motors will bolt on the firewall no problem.
The issue is with the shaft size at the back.
70-71 uses a larger shaft size hole for the cam arm.
72-74 is smaller.
You will have to open up the hole on your cam arm in order to fit it on the motor.
HEMI472 .....If your motor is dated up to about 080/2 you could have a
flat sytle switch plate like 70-71. Other wise you would have a
black bakelit plate.
Jules
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781324
08/23/10 05:32 PM
08/23/10 05:32 PM
MD
MD
ok thanks everyone
so i take it the wires and switches are the same????? thanks again Ed
Re: 1972 challenger wiper motor [Re: HEMI472] #781325
08/23/10 07:04 PM
08/23/10 07:04 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
The wiring is all the same on the motor but 70 & 71 models used a variable speed switch and the 72 - 74 used a dedicated three speed switch. There wiring into the switch is different with 70 - 71 switches using two separate connectors and the 72 - 74 using just one. Same wiring on the main wiring harness, just different individual connector locations.
Slotts
Re: 1972 challenger wiper motor [Re: Slotts] #781326
08/24/10 08:48 AM
08/24/10 08:48 AM
super gas
super gas
Visual.70-71
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781327
08/24/10 08:48 AM
08/24/10 08:48 AM
super gas
super gas
72-74
Jules
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781328
08/24/10 09:02 AM
08/24/10 09:02 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
installed - 1970 Cuda Rallye dash with variable wipers
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781329
08/24/10 01:35 PM
08/24/10 01:35 PM
cataclysm80 Offline
cataclysm80  Offline
Or just use the matching cam arm, then it will bolt right up. You reproduce the cam arms right Jules?
Tav
Re: 1972 challenger wiper motor [Re: cataclysm80] #781330
08/24/10 03:34 PM
08/24/10 03:34 PM
super gas
super gas
I do not produce 70/71 cam arms for 72 and up linkages.
I produce 72/74 cam arms for 70/71 linkages.
Jules
Re: 1972 challenger wiper motor [Re: cataclysm80] #781331
08/25/10 06:57 PM
08/25/10 06:57 PM
Sunny FL
P
p4m Offline
p4m  Offline
P
Sunny FL
I don't reproduce them but I do have them. The part number for the 72-74 is 3431518 and I have several which have been cleaned up, prepped, are plated and ready to go. Passion4Mopars
Re: 1972 challenger wiper motor [Re: p4m] #781332
08/25/10 07:05 PM
08/25/10 07:05 PM
super gas
super gas
That 518 arm will not fit a 70-71 motor shaft.
You will have to carve out the hole.
Email me and I will set you up correctly without you having to carve anything.
Jules
450-656-5438
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781333
08/25/10 08:37 PM
08/25/10 08:37 PM
Sunny FL
P
p4m Offline
p4m  Offline
P
Sunny FL
OP asks if a 70-71 wiper motor will work with a 72 Challenger. No, but the odds are high with the 72 Challenger that he has a 3431102 drive link and 3431518 crank arm (although we don't know, the OP doesn't offer that info). The output shaft on the 70-71 has a larger diameter 5/16", .329 wide and is .370 tall where the output shaft on the 72-74 crank arm is 1/4, .265 wide and .489 tall, therein lies one of the problems. (Actually....its the threads and nuts that are different not the shafts. The link has bronze bushings to accommodate the 2 different size cogs....hence two different links that don't mix with 2 different crank arms)
In 1972 Chrysler went to the small latch and if you had a mid 68 to 71 anything with a 3/variable speed and ordered a gear and latch package after they ran out of the early style....you got the small cog cause it was engineered to work on all the earlier 3/Var spd motos from mid 68 on up. Some people think it's not right to put that combination together, but Chrysler did it.
If I were the OP and I'm going to assume since he has a 72 Challenger, that his drive link is 3431102 and the crank arm is 3431518. Rather than replace my drive link and my crank arm to do this conversion, I'd simply remove the switch plate, replace the gear latch/output shaft with a small diameter gear latch (short style) replace the switch plate cover with the correct timing for my E body and be off to the races installing that motor. Cheaper, less aggravation and less time involved.
If the OP has the 70-late 71 drive link (PN 2822293), easiest way to handle things is to get a 2822289 crank arm with the 70-71 wiper motor and he's off to the races again...it ain't rocket science?
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781334
08/25/10 09:07 PM
08/25/10 09:07 PM
super gas
super gas
I have a much easier solution without assuming anything
and it does not involve opening the motor or messing with part numbers . Simple bolt on.
HEMI572 email me or pm me your phone number if you are interested.
Jules
Re: 1972 challenger wiper motor [Re: JulesdaWiperman] #781335
08/25/10 09:23 PM
08/25/10 09:23 PM
Sunny FL
P
p4m Offline
p4m  Offline
P
Sunny FL
Simple "bolt on without assumptions or worrying about part numbers"???? I'm sure I'm as curious as next person on this one
Re: 1972 challenger wiper motor [Re: HEMI472] #781336
08/25/10 10:56 PM
08/25/10 10:56 PM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I know if you have the motor and arms off a 73 it will work on a 1970 RT. I put it all on mine. Thanks to Jules for the FREE help and advise! Looks like he is offering his help to you as well as PassionforMopars. Use the experts advice, it will save you $$$$
Joe Sr
Re: 1972 challenger wiper motor [Re: p4m] #781337
08/26/10 03:03 AM
08/26/10 03:03 AM
super gas
super gas
It's actually quite simple if you take a moment to think it out.
I won't give away ALL my tricks.
Jules
