Re: 1972 challenger wiper motor
[Re: HEMI472]
#781319
08/23/10 02:13 PM
08/23/10 02:13 PM
Posts: 2,648 GA
Boosted
GA
They must be diffrent ... i looked them up online and can find a reman motor for a 72 3 spd or 2 spd but nothing for a 70-71...
3spd was 63 and 2spd weas 48 at oriely for a 72...
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: burdar]
#781321
08/23/10 03:19 PM
08/23/10 03:19 PM
Posts: 781 MD
HEMI472
MD
The motors are different in appearance but I think they will work. Jules will know for sure. Hopefully he will see this.
my car is a 72 but the wiper motor on it looks like the 70-71 style not the 72-74 style with the black plastic cover. could my car be a early 72 and have a 71 wiper???? thanks ed
[Re: HEMI472]
#781322
08/23/10 03:26 PM
08/23/10 03:26 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: JulesdaWiperman]
#781329
08/24/10 01:35 PM
08/24/10 01:35 PM
Posts: 4,165 Florida
cataclysm80
You will have to open up the hole on your cam arm in order to fit it on the motor.
Or just use the matching cam arm, then it will bolt right up. You reproduce the cam arms right Jules?
Tav
#781333
08/25/10 08:37 PM
08/25/10 08:37 PM
Posts: 114 Sunny FL
p4m
Sunny FL
OP asks if a 70-71 wiper motor will work with a 72 Challenger. No, but the odds are high with the 72 Challenger that he has a 3431102 drive link and 3431518 crank arm (although we don't know, the OP doesn't offer that info). The output shaft on the 70-71 has a larger diameter 5/16", .329 wide and is .370 tall where the output shaft on the 72-74 crank arm is 1/4, .265 wide and .489 tall, therein lies one of the problems. (Actually....its the threads and nuts that are different not the shafts. The link has bronze bushings to accommodate the 2 different size cogs....hence two different links that don't mix with 2 different crank arms)
In 1972 Chrysler went to the small latch and if you had a mid 68 to 71 anything with a 3/variable speed and ordered a gear and latch package after they ran out of the early style....you got the small cog cause it was engineered to work on all the earlier 3/Var spd motos from mid 68 on up. Some people think it's not right to put that combination together, but Chrysler did it.
If I were the OP and I'm going to assume since he has a 72 Challenger, that his drive link is 3431102 and the crank arm is 3431518. Rather than replace my drive link and my crank arm to do this conversion, I'd simply remove the switch plate, replace the gear latch/output shaft with a small diameter gear latch (short style) replace the switch plate cover with the correct timing for my E body and be off to the races installing that motor. Cheaper, less aggravation and less time involved.
If the OP has the 70-late 71 drive link (PN 2822293), easiest way to handle things is to get a 2822289 crank arm with the 70-71 wiper motor and he's off to the races again...it ain't rocket science?
[Re: HEMI472]
#781336
08/25/10 10:56 PM
08/25/10 10:56 PM
Posts: 1,324 Western Pa
joewhite440
Western Pa
I know if you have the motor and arms off a 73 it will work on a 1970 RT. I put it all on mine. Thanks to Jules for the FREE help and advise! Looks like he is offering his help to you as well as PassionforMopars. Use the experts advice, it will save you $$$$
Joe Sr
[Re: p4m]
#781337
08/26/10 03:03 AM
08/26/10 03:03 AM
Posts: 2,984 Montreal,Quebec,Canada
JulesdaWiperman
super gas
super gas
Simple "bolt on without assumptions or worrying about part numbers"???? I'm sure I'm as curious as next person on this one
It's actually quite simple if you take a moment to think it out. I won't give away ALL my tricks. Jules
