Anyone tap a cylinder head? #780628
08/22/10 07:25 PM
08/22/10 07:25 PM
Cen Fla
j3wbagell Offline OP
Cen Fla
the screw before the header is stripped and needs to tapped. It shoot out water when filling the radiator and gas when turned on, this was not happening before. IS that normal?
Plan on taking it to a shop to get tapped anyone done it themselves?
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780629
08/22/10 07:43 PM
08/22/10 07:43 PM
Minn
SportF Offline
SportF  Offline
Minn
Well, you probably need to re-thread it with a heli-coil kit. If you have ever tapped something before it is pretty easy. If you haven't then you should have someone give you a little lesson on it. You could probably do it on the engine. Ask around, some of your car friends might already have a heli-coil kit. Good luck!
Re: Anyone tap a cylinder head? [Re: SportF] #780630
08/22/10 07:57 PM
08/22/10 07:57 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
You say it shoots out gas??? That's not normal! The Exhaust studs go into the water jacket, so leaking coolant is normal, but I wouldn't think leaking gas is normal. Sounds like something else to me. Jeff
Re: Anyone tap a cylinder head? [Re: 1969RR] #780631
08/22/10 08:04 PM
08/22/10 08:04 PM
Cen Fla
Cen Fla
it doesnt shoot gas like it shoots coolant. the gass is more of a spray but it definitely has persistence. it almost sounds like a rod is knocking with the header not completely attached.
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780632
08/22/10 08:47 PM
08/22/10 08:47 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
There is no way that there can be gas coming out of that bolt. Are you sure that it is stripped or do you just need sealer on that bolt? On a small block it is just the end bolt on each head that is wet. If it is a big block all of them are wet and should have sealer.
Re: Anyone tap a cylinder head? [Re: MoparforLife] #780633
08/22/10 08:51 PM
08/22/10 08:51 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
If you have gas comming out an exhaust stud, you got major problems. Crack in the cyl head might cause that. You'd better make sure that is gas, and if it actually is gas, plan on a tear down! Jeff
Re: Anyone tap a cylinder head? [Re: MoparforLife] #780634
08/22/10 09:03 PM
08/22/10 09:03 PM
Cen Fla
Cen Fla
I have a SB, luckily it is the end bolt. I took a bolt to HD and wound up getting a few at ace, they had better machined tips, but none of them would screw all the way in and had bent threads after taking it out.
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780635
08/22/10 11:11 PM
08/22/10 11:11 PM
Cen Fla
Cen Fla
Anyone have a solution so i can drive the car to the shop? at least 15 miles
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780636
08/23/10 12:13 AM
08/23/10 12:13 AM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
use a bolt severely gooed with rtv sealant. like black or something. Even liquid teflon tape. Heavy goo,and bolt it on. Let it comeletely dry before you move the car.
Also if you a Helicoil, and it sound like you might have to, use the liquid teflon on the outside of the Heli-Coil so that has a good seal too.
Re: Anyone tap a cylinder head? [Re: GwaiiEagle] #780637
08/23/10 12:21 AM
08/23/10 12:21 AM
Cen Fla
Cen Fla
i should be taking it to a shop, i need to re rout the exhaust as well so hopefully i can get that done. After sealing the bolt how can i get the remaining seal out of the head? How high is the risk in doing that instead of towing it to a mechanic?
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780638
08/23/10 10:54 AM
08/23/10 10:54 AM
Indiana
mt162 Offline
mt162  Offline
Indiana
I think he means exhaust leak - not a gas leak.
Re: Anyone tap a cylinder head? [Re: mt162] #780639
08/23/10 10:56 AM
08/23/10 10:56 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
hire a rollback
Re: Anyone tap a cylinder head? [Re: mt162] #780640
08/23/10 02:27 PM
08/23/10 02:27 PM
Cen Fla
Cen Fla
gas is coming out the engine of the first hole. Is it safe to rtv seal in there?
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780641
08/23/10 02:34 PM
08/23/10 02:34 PM
Upper Midwest
Upper Midwest
Gasoline (liquid) or exhaust.
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780642
08/23/10 02:48 PM
08/23/10 02:48 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
How about a photograph?
Gas as in petrol or gas as in steam from the rad?
Re: Anyone tap a cylinder head? [Re: GwaiiEagle] #780643
08/23/10 06:33 PM
08/23/10 06:33 PM
Cen Fla
Cen Fla
i don't know what to call it sorry i assume cylinder 5...
here you can see the empty hole
after ignition...
and a video just if you need
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780644
08/23/10 06:45 PM
08/23/10 06:45 PM
Upper Midwest
Upper Midwest
to me it looks to be Right front cylinder and is number 2
Left side of engine (drivers side) 1-3-5-7
right side 2-4-6-8
Re: Anyone tap a cylinder head? [Re: MoparforLife] #780645
08/23/10 06:53 PM
08/23/10 06:53 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Why do you say its gasoline and not antifreeze????Smell,taste,combustable???
Re: Anyone tap a cylinder head? [Re: 70RR383] #780646
08/23/10 06:59 PM
08/23/10 06:59 PM
Cen Fla
Cen Fla
because there is no anti freeze the rad is clear, i just want to be able to get it to the mechanic and i cant drive with out any fluid in the radiator.
Re: Anyone tap a cylinder head? [Re: j3wbagell] #780647
08/23/10 08:05 PM
08/23/10 08:05 PM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
You can do the tap with a heli-coil. Or get the shop to do it.
Getting it to the Shop?: Seriously goo the bolt and bolt it in as able. Let it dry overnight.
Yerself: I recommend a helicoil and liquid teflon on the outside of the helicoil when you screw it in.
