UBJ removal tips? #78008
06/21/08 10:14 PM
06/21/08 10:14 PM
Riverside, Ca
R70RUNNER Offline OP
Riverside, Ca
I'm trying to get the upper ball joints out of my b-body, Arms are still in the car, rest of the susension is gone. Car on stands.
BJ's are soaked with PB blaster, correct socket, long handle breaker bar and even a cheater pipe on the end, I can get it to budge! What next guys, heat? longer pipe? rented gorilla? Gotta get these things out asap
What's the trick?
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: UBJ removal tips? [Re: R70RUNNER] #78009
06/21/08 10:16 PM
06/21/08 10:16 PM
ky.
K
kenworth_goose Offline
K
ky.
Heat them up red hot spray with cold water. Reheat red and they will come loose.
Re: UBJ removal tips? [Re: kenworth_goose] #78010
06/21/08 10:18 PM
06/21/08 10:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Ingersol Rand 1/2" Impact..
Re: UBJ removal tips? [Re: R70RUNNER] #78011
06/21/08 10:19 PM
06/21/08 10:19 PM
IN
ahy Offline
ahy  Offline
IN
Longer pipe. Gentle heat (propane) could help too.
Re: UBJ removal tips? [Re: kenworth_goose] #78012
06/21/08 10:20 PM
06/21/08 10:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Then throw the control arms in the junk pile...
Re: UBJ removal tips? [Re: 1_WILD_RT] #78013
06/21/08 10:56 PM
06/21/08 10:56 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
That's what i use at work.
If you can't get them out, and don't have a air compressor, and good strong air gun, then take the upper a arms out of the vehicle and take them to your local mechanic and have him zap them out with his air gun.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: UBJ removal tips? [Re: hemi71x] #78014
06/22/08 12:21 AM
06/22/08 12:21 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had to use an impact gun too. Mine was a cheap one so it even took some time using it. Since then I bought a nice Snap-on impact but haven't had to test it on the upper ball joints.
Re: UBJ removal tips? [Re: R70RUNNER] #78015
06/22/08 12:51 AM
06/22/08 12:51 AM
AndyF Online content
AndyF  Online Content
It takes a lot to get some out of there. I used to use two long cheater bars with a guy on each one to bust the really stubborn ones loose.
Re: UBJ removal tips? [Re: AndyF] #78016
06/22/08 01:24 AM
06/22/08 01:24 AM
Riverside, Ca
Riverside, Ca
Thanks for the tips guys, I'll borrow a better impact, I have very basic unit, but a decent compressor, then the propane torch. I wanted to hear if heat is appropriate on the arms before I went that route. Not so sure I want to try the water though.
If push comes to shove, I'll take them over to a local truck shop and have the boys with BIG impacts go at 'em.
Re: UBJ removal tips? [Re: R70RUNNER] #78017
06/22/08 01:47 AM
06/22/08 01:47 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
A strong impact gun and some penetrating oil should do it.I'm not against using some heat when necessary but have never needed it on upper ball joints.
Re: UBJ removal tips? [Re: R70RUNNER] #78018
06/22/08 11:10 AM
06/22/08 11:10 AM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Heat the area where the treads are and melt some candle wax into the threads. It will wick in and lubricate the threads for easier removal.
Ron
Re: UBJ removal tips? [Re: Ronnman] #78019
06/22/08 12:30 PM
06/22/08 12:30 PM
BDW Offline
BDW  Offline
Longer pipe should do the trick. I went to Home Depot and got a 3" pipe, 4ft long. Worked great
Old saying "With a long enough lever, you can move the world"
Re: UBJ removal tips? [Re: BDW] #78020
06/22/08 01:36 PM
06/22/08 01:36 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I had a hard time getting the ones off my dart when they were on the car due to the funky angle they sit at when unsupported. The socket kept trying to roll off and I could see myself loosing some skin eventually. I pulled them off the car and slid a steel rod through the ends and then clamped the rod in a vice so the ball joint was more parallel to the ground. One came out with the breaker bar and the other needed the impact gun.
Re: UBJ removal tips? [Re: Neil] #78021
06/22/08 01:55 PM
06/22/08 01:55 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've removed hundreds of them, you can literally hold the control arm in your left hand & the impact in your right...It's the way an impact gun hammers (impacts) as it turns, they come out quite easily...
Re: UBJ removal tips? [Re: 1_WILD_RT] #78022
06/22/08 02:01 PM
06/22/08 02:01 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
But I like doing things the hard way!
I tried the breaker bar first since I didn't have an impact. Once I exhausted that route I borrowed an impact gun to take the last one out....and wished I would have tried the impact gun first.
Re: UBJ removal tips? [Re: Neil] #78023
06/22/08 02:04 PM
06/22/08 02:04 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Boy I know the feeling...
Re: UBJ removal tips? [Re: 1_WILD_RT] #78024
06/22/08 04:14 PM
06/22/08 04:14 PM
Riverside, Ca
Riverside, Ca
They are out! Borrowed an awsome (IR Titanium) impact, and that did the trick. What a nice tool
Thanks again for the help guys!
Re: UBJ removal tips? [Re: R70RUNNER] #78025
06/22/08 11:40 PM
06/22/08 11:40 PM
S Williamsport
therick Offline
therick  Offline
S Williamsport
Snap on impact guns are junk. IR are the best you can buy. I've had both. Never will go back to Snap on. IR forever
