78 motor home drive train #779866
08/21/10 07:42 PM
08/21/10 07:42 PM
Greenville Pa.
rdagw Offline OP
rdagw  Offline OP
Greenville Pa.
Would it be worth it to get the 440 engine and trans. out of it? Can get it for cheap money. Does the trans have the extra clutch drum in it?
Leo
Re: 78 motor home drive train [Re: rdagw] #779867
08/21/10 08:06 PM
08/21/10 08:06 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
The 727 may be a shorty, but should have the heavy duty internals. If you get it, and the passenger side exhaust manifold isn't cracked...I may be willing to give you some of your cheap money back.
Re: 78 motor home drive train [Re: rdagw] #779868
08/21/10 08:17 PM
08/21/10 08:17 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
DEFINE ...cheap money ?? .... extra clutch drum ? ... NO motorhome trans ever had a hemi/6 pack setup in it that I am aware of.
Re: 78 motor home drive train [Re: dOc …] #779869
08/21/10 08:21 PM
08/21/10 08:21 PM
JDMopar Offline
JDMopar  Offline
Hey Doc....I think he may mean the extra planetary gears. Didn't all HD trans have those? Oh....and thanks for the brake hose tip One of mine was rusty, just like you said.
Re: 78 motor home drive train [Re: JDMopar] #779870
08/21/10 08:31 PM
08/21/10 08:31 PM
Florida STAYcation
Florida STAYcation
JD ... HD P-gears meaning 4 gear set ? .. roger that. Your brake hose ...was rusted up enough to close-off the return of brake-fluid so the brake caliper was not releasing ?
Re: 78 motor home drive train [Re: dOc …] #779871
08/22/10 10:44 AM
08/22/10 10:44 AM
scratchnfotraction Offline
I would say so,if it runs good
i got my 78 440/727 shorty for my 88 truck build
75,000 miles on the clock for 300$
swaped oil pans from front sump to rear sump and bolted it right in on the 85 frame
FYI the shorty tranz could have the tranz mount moved forward 2" compaired to a long tail 727...I made a xmember from square stock and the stock lower brackets and used the MH flat rubber tranz mount,it had the speedo hook up in a diff spot-no worky with stock xmember...some shortys may have the park brake drum on the tail shaft also
the tranz will be the HD with 4 planatary gears but no hemi clutch drum
I used a CRT full manual Vb to drop the stock throttle pressure linkage (hard to come by and big $$$)
thats it in the sig pic
Re: 78 motor home drive train [Re: scratchnfotraction] #779872
08/22/10 10:48 AM
08/22/10 10:48 AM
Re: 78 motor home drive train [Re: scratchnfotraction] #779873
08/22/10 03:21 PM
08/22/10 03:21 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Nice work bench.
Re: 78 motor home drive train [Re: Commando1] #779874
08/22/10 06:46 PM
08/22/10 06:46 PM
all complete and you can have it
Re: 78 motor home drive train [Re: dOc …] #779875
08/22/10 11:49 PM
08/22/10 11:49 PM
JDMopar Offline
JDMopar  Offline
Yep...little bracket in the middle of the hose was rusted. Here's the shocker....O'Reilys had BOTH hoses in stock!
Re: 78 motor home drive train [Re: rdagw] #779876
08/23/10 02:28 AM
08/23/10 02:28 AM
california
moparmanof85 Offline
california
its definantly worth it. i pulled a 413 and hd 727 out of a 40 footer a few years back. we used to take that damn thing over the rockies with a trailer loaded to the gills. the tranny is a fine one. keep it forever. they'll never make em again.
