Re: Which carb for a mild d/d 360?
[Re: None2Slow]
#779788
08/21/10 07:01 PM
08/21/10 07:01 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
The 600 would be fiine but myself I would use the 750 vac and jet i t accordingly in the front. It will only use what it needs for secondaries. Vac secondaries are great for the street.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: mark7171]
#779792
08/22/10 12:11 AM
08/22/10 12:11 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
The vacuum secondary holleys never see full cfm potential, unless you are reving that 360 out to 7000.
WHAT???
Ever use of a spring kit.
A 600 or 750 VS carb will work well on a d/d 360.
[Re: RobX4406]
#779794
08/22/10 03:45 AM
08/22/10 03:45 AM
Posts: 1,261 ILL
mark7171
ILL
WHAT???
The chart stands correct.
My 323 gets about 500 cfm from a 600 holley vac sec with the yellow spring. a snorkel air cleaner gets 500rpm open sooner, a KxN cold air would be 500 rpm later in the RPM range.
Shifting at 5-5200 rpm tops with hydraulic lifters.
[Re: None2Slow]
#779795
08/22/10 11:32 AM
08/22/10 11:32 AM
Posts: 5,270 Missouri
MY340
Missouri
600cfm better mileage probably? 750cfm definitely more power! I'd go with the 750cfm for sure.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
